Ghostdad Posted April 7, 2007 Share Posted April 7, 2007 Does someone know where to find a walkthrough on the alternator belt replacement. I've tried the search function with no results.. I thought I'd take advantage of this cold and snowy weekend and do the annual service on my bike. I want to check and probably replace the belt. This way I know when it was done for proper future service intervals. Thanks in advance for any and all help.. Dave Link to comment
Tony_K Posted April 7, 2007 Share Posted April 7, 2007 When searching the site use these parameters +belt +replacement in oilheads You get stuff like this http://bmwsporttouring.com/ubbthreads/sh...true#Post774062 What you want is in this thread. Link to comment
Ghostdad Posted April 7, 2007 Author Share Posted April 7, 2007 Thanks for the info. This is one item I will keep an eye on, cause I don't want to have to change a belt on the side of the road... But I will keep a spare on the bike just in case, and the proper allen wrench in the tool kit. Is there an easier way of removing the alternator cover without removing the shark fin? Just curious for future reference... Thanks again for your help.. Dave Link to comment
Tony_K Posted April 7, 2007 Share Posted April 7, 2007 The fin comes off so easy that after you have done it once it will be a after thought. You did download the PDF correct? Keep that around as all the most common items are there for quick reference. Link to comment
KMG_365 Posted April 8, 2007 Share Posted April 8, 2007 Is there an easier way of removing the alternator cover without removing the shark fin?Well, not the first time, but I just re-tensioned mine after changing at Phil's and cutting my cover in half. This time it took me all of 10 minutes from start to finish and I never touched a tupperware screw. I would really recommend one of those 13mm ratcheting box end wrenches--especially if you have an Ohlins front shock as the clearance to that top bolt is a PITA. Link to comment
Ghostdad Posted April 8, 2007 Author Share Posted April 8, 2007 Yes I did download the "PDF" and thanks again... I thought I remembered someone saying they cut the cover in half. If it makes it so you can do it with out removing the tupperware, I think I'll pull the cover again and cut for future access.. Any specific spot to cut it to make the job easier? Thanks Dave Link to comment
Limecreek Posted April 8, 2007 Share Posted April 8, 2007 I have a video I can email you if you like. PM me your addy and I'll send you a copy. Link to comment
KMG_365 Posted April 8, 2007 Share Posted April 8, 2007 Any specific spot to cut it to make the job easier? I cut it across the middle right directly behind the telelever so that it doesn't pick up too much more sand/grit than the side vents already allow. This leaves two screws for the top half and two for the bottom. Link to comment
Ghostdad Posted April 8, 2007 Author Share Posted April 8, 2007 Any specific spot to cut it to make the job easier? I cut it across the middle right directly behind the telelever so that it doesn't pick up too much more sand/grit than the side vents already allow. This leaves two screws for the top half and two for the bottom. Thanks Jamie.. That was one thing I was concerned about when I first read of cutting it in half, was dirt and debri getting in there. But after pulling the cover and seeing all the junk in there to begin with I don't think cutting it is going to make much difference anyway...LOL Thanks everyone for the great info. This place is great. Since my wife has to work today, I have all day to finish the bike. 1) pull cover and cut it. 2) do the TBS 3) flush brake fluid Thanks again for the help. Happy Easter!! Dave Link to comment
