lthj75 Posted April 7, 2007 Share Posted April 7, 2007 Some of you asked to see what I made, so here it is. Nothing too fancy, but it certainly worked out great! Didn't want to spend the insane amount of money for the pre-made mounts out there....and I wanted a center mount bracket so I fabricated the following for a whole $20.... 1) Started with a piece of Aluminum stock from a local Ace Hardware 2) Cut it and grinded/smoothed down the edges 3) Drilled mounting holes and RAM Mount hole 4) Painted with Aluminum Rustoleum 5) Mounted RAM and mounted to the bike! Link to comment
lthj75 Posted April 11, 2007 Author Share Posted April 11, 2007 Update - used the zumo on my first lengthy ride and the set-up was great! No glares, easy to see and close enoght that I could wear wired earplugs with no adapters. Just wanted to share incase others were interested. Link to comment
finkb Posted April 17, 2007 Share Posted April 17, 2007 Do you have and use the BMW tank bag? If so, does it interfere with or block your view of the Zumo? Link to comment
lthj75 Posted April 17, 2007 Author Share Posted April 17, 2007 Sorry - I do not use a tank bag.....but if it helps, the pics I took were from sitting on the bike. So if you can see the spot I have my GPS mounted, you should be fine. Also keep in mind that its on a ball ram mount - so its fully adjustable height wise..... Link to comment
PhysicsWinz Posted July 16, 2007 Share Posted July 16, 2007 that's pretty cool. did you put spacers under the new bolts so that torquing them would not bend the aluminum inward? Do you feel the integrity of the handlebars is just as good? I would be interested in doing a similar arrangement on my roadster, but with 2 ram mounts--one for the zumo and one for a sirius radio. John Link to comment
jakfrost Posted July 17, 2007 Share Posted July 17, 2007 Why not just get one of these? Pretty simple to install, (tap,tap,tap), and look pretty neat too... Click to enlarge: 62.00 inlcudes the solid billet aluminum base, 1" Ram ball mount and shipping. Jim W. Link to comment
lthj75 Posted July 18, 2007 Author Share Posted July 18, 2007 that's pretty cool. did you put spacers under the new bolts so that torquing them would not bend the aluminum inward? Do you feel the integrity of the handlebars is just as good? I would be interested in doing a similar arrangement on my roadster, but with 2 ram mounts--one for the zumo and one for a sirius radio. John No spaces - the aluminum flexed a little bit when the bolts were torqued down.....no change or compromise at all.....still love it. For $20 can't go wrong! Link to comment
