photomd Posted April 6, 2007 Share Posted April 6, 2007 Hi all, I've got a problem. My 96 RSL had showed a brake fault on the way home: alternating lights like a low voltage. It didn't reset on restart. I get home and turn off the bike and can hear the ABS motor under the tank with the key off. So I pull the right panel and disconnect the battery. I'm showing a #6 fault: ABS relay. Where the heck is the relay? Is it under the black plastic on the right hand side of the ABS unit and if so, how do I remove it? That has some weird screws holding the plastic cover on. Any help will be greatly appreciated. Thanks. Link to comment
Ken H. Posted April 6, 2007 Share Posted April 6, 2007 Is it under the black plastic on the right hand side of the ABS unit Yes. Take out the screw and the cover slides off. The relay is part #61362306526 BTW. Link to comment
photomd Posted April 6, 2007 Author Share Posted April 6, 2007 Thank you. Is the relay inside the black cover or is the black cover the relay? Sorry to be dense...I don't see an easy wire connection;just power and ground going into the ABS unit and four wires disappearing into the black plastic case and these wires go directly into the main wiring harness. Link to comment
John Dickens Posted April 6, 2007 Share Posted April 6, 2007 Here's its picture! It's number 5 on the diagram. Link to comment
photomd Posted April 6, 2007 Author Share Posted April 6, 2007 Thank you. I couldn't figure out if that plastic door slid up or not...better to find out in the beginning than ordering parts later. Link to comment
