majordad Posted April 1, 2007 Share Posted April 1, 2007 I took a pretty good trip this weekend travelling over 720 miles. Virtually all of it was interstate travelling with about 30 miles being city (stop and go). While coming back I got to thinking what the average interval mileage has been for those here needing to change their clutch. I have 23k miles on my 2005 RT. All things being equal....around what mileage might I sense clutch problems? I understand driving habits, maintenance, etc. effect wear of the clutch and that mileage isn't the determinate for clutch replacement like a timing belt or oil change would be but wondered when those here are having to change their clutch. Link to comment
David Posted April 1, 2007 Share Posted April 1, 2007 If your technique is good (modest acceleration until full engagement), and baring no other issues, it should last way over 100k. Link to comment
Paul Mihalka Posted April 1, 2007 Share Posted April 1, 2007 Most clutches die for other reasons than normal friction surface wear. Clutch splines, gearbox input shaft seal, engine crankshaft seal, after '02 hydraulic clutch slave cylinder failure, all can kill the clutch. The only really worn out clutches I heard of were in police bikes. Link to comment
Bob Palin Posted April 1, 2007 Share Posted April 1, 2007 Mine was still working fine when it was changed at 96,000 together with the transmission, which wasn't working so fine. Unfortunately they didn't keep the parts for me to see so I don't know how worn it was. Link to comment
Stan Walker Posted April 1, 2007 Share Posted April 1, 2007 I measured my '02's clutch when I did a spline lube at 69,000 miles. It was about 1/3 gone. I put it all back and I will check it again at 150,000 when I do my next spline lube. New clutch thickness is 0.257" My clutch thickness was 0.235" Wear limit for 02 RT is 0.189" Usable material on new. 0.068" Remaining usable clutch 0.046" I am pretty easy on my clutch. And on my bike. About 50% of my mileage is from trips, the rest from comuting in Los Angeles traffic. Stan Link to comment
majordad Posted April 1, 2007 Author Share Posted April 1, 2007 I am easy on my clutch too.....because I am getting old and know that these things are expensive to fix. Is spline lubing for advanced mechanicing/the dealer? Link to comment
Stan Walker Posted April 1, 2007 Share Posted April 1, 2007 Is spline lubing for advanced mechanicing/the dealer? It'z time consuming, but doesn't require any fancy tools or skills. The few special tools that are needed can be made for a few dollars. I wouldn't worry about it a lot at your mileage unless there is some sort of a problem. Stan Link to comment
DavidEBSmith Posted April 2, 2007 Share Posted April 2, 2007 And for those who have 1100s with the clutch cable, maintain proper clutch freeplay. There were some premature clutch failures in the early models that were attributed to insufficient freeplay. (And the 1996 models with the bad seals that leaked oil onto the clutch plates). The early failures created something of a bad reputation for clutch life that seemed to go away when the clutch lever freeplay specification was increased. But you don't have to worry about that with your 2005. Link to comment
Stan Walker Posted April 2, 2007 Share Posted April 2, 2007 The early failures created something of a bad reputation for clutch life Some of the short life was real, BMW changed the design in '97 to extend the life. Still, even with the original design 100,000 miles was possible. When I did the spline lube on Jan's '96 RT at 71,000 I found that the clutch was about 2/3's worn out. I replaced it to avoid opening it up again prior to it's next spline lube. Stan Link to comment
Tominator Posted April 3, 2007 Share Posted April 3, 2007 This guys a genius! Why didnt we think of this? Clutch Spline Lube in One Hour? Can this be possible! You Bet! Link to comment
SWB Posted April 3, 2007 Share Posted April 3, 2007 This guys a genius! Why didnt we think of this? Clutch Spline Lube in One Hour? Can this be possible! You Bet! Actually, I think that Jamie gets the credit for "brilliance" here, unless it's a case of "great minds think alike". Link to comment
