Lawman Posted March 29, 2007 Share Posted March 29, 2007 Okay, checked throttles bodies like this using a Twinmax: 1. Turn on power 2. Connect rubber hoses to each throttle body 3. Adjust sensitivity to MAX and adjust zero knob until needle is straight on zero. 4. Turn sensitivity knob fully to MIN. 5. Start engine 6. Rev and hold engine at several different ranges from 1500 to 4000 r.p.m. The needle barely even moved. At worst was about 1/4 off zero to the left of zero..Do I need to make any adjustment? If so, how? I assume it's done using the two nuts on the right side throttle body very near where the hose connects to the throttle body? Also, I did this without the muffler on as I am waiting on a new back tire to be installed..Would this have any effect? Link to comment
Leo Flor Posted March 29, 2007 Share Posted March 29, 2007 Okay, checked throttles bodies like this using a Twinmax: 1. Turn on power 2. Connect rubber hoses to each throttle body 3. Adjust sensitivity to MAX and adjust zero knob until needle is straight on zero. 4. Turn sensitivity knob fully to MIN. 5. Start engine 6. Rev and hold engine at several different ranges from 1500 to 4000 r.p.m. The needle barely even moved. At worst was about 1/4 off zero to the left of zero..Do I need to make any adjustment? If so, how? I assume it's done using the two nuts on the right side throttle body very near where the hose connects to the throttle body? Also, I did this without the muffler on as I am waiting on a new back tire to be installed..Would this have any effect? Check your number 4 step. With your Twinmax's sensitivity set at minimum, it may not be registering a small difference in pressure between the two sides. That's the first thing I check when my needle barely moves. To confirm each reading, try again at a slightly higher sensitivity. Be judicious when raising the sensitivity -- a needle that's jumping around too much will drive you nuts! I don't know if having the exhaust muffler off would affect the Twinmax's readings. Good luck! Link to comment
Lawman Posted March 29, 2007 Author Share Posted March 29, 2007 Oh yeah I left that part off..I did move the sensitvity almost all the the way to max when revving and it did not have much effect on the needle.. Thanks Link to comment
Leo Flor Posted March 29, 2007 Share Posted March 29, 2007 Oh yeah I left that part off..I did move the sensitvity almost all the the way to max when revving and it did not have much effect on the needle.. Thanks You're welcome. I can't think of anyhing else off-hand. You're good to go! No, wait...better get that muffler back on first. Link to comment
Albert Posted March 30, 2007 Share Posted March 30, 2007 Billy, while you're waiting for someone who knows more than me to respond, can I ask if you had to remove the tupperware to get the Twinmax hooked up? Thanks, Link to comment
aggieengineer Posted March 30, 2007 Share Posted March 30, 2007 I did on mine. I've checked mine with a Twinmax three times in 7000 miles and it's been virtually dead-center each time. Link to comment
Jim VonBaden Posted March 31, 2007 Share Posted March 31, 2007 I did on mine. I've checked mine with a Twinmax three times in 7000 miles and it's been virtually dead-center each time. In my experience, with a couple dozen TB syncs on Hexheads, I have found few to be off at all after the first 6K service. Jim Link to comment
IndianaHarvey Posted April 1, 2007 Share Posted April 1, 2007 I did on mine. I've checked mine with a Twinmax three times in 7000 miles and it's been virtually dead-center each time. serIn my experience, with a couple dozen TB syncs on Hexheads, I have found few to be off at all after the first 6Kvice. Jim So Jim, are you saying that it may not be necessary to check the throttle sync or at least not at every service interval? Link to comment
Jim VonBaden Posted April 2, 2007 Share Posted April 2, 2007 I did on mine. I've checked mine with a Twinmax three times in 7000 miles and it's been virtually dead-center each time. In my experience, with a couple dozen TB syncs on Hexheads, I have found few to be off at all after the first 6Kvice. Jim So Jim, are you saying that it may not be necessary to check the throttle sync or at least not at every service interval? If your bike is running well, I am confident you could skip it if you wish. It certainly wont hurt the bike, though you may not be running at peak performance. Most likely you will be very close. Jim Link to comment
