LGannon Posted March 25, 2007 Share Posted March 25, 2007 Are these products the same in different packages? is one any better than the other? Link to comment
Tony_K Posted March 25, 2007 Share Posted March 25, 2007 Damn boy! Change your question to religion then as it again. Your basically asking the same thing. Link to comment
John Bentall Posted March 25, 2007 Share Posted March 25, 2007 Well Les, It does depend on whether you are going to fit the gear yourself or whether you want some help. Does your 1150RT have an integrated radio and do you have GPS, Bike-to-Bike etc and do you want to integrate an i-Pod. As a committed, 100% satisfied Autocom user (who thinks Autocom rule) I should be sending you to Hursts BMW who are Autocom agents. I believe the Autocom active microphone system is superior in that it shuts off when not talking - but there is a lag and possible lost words when speaking. However as a Dubliner you also have a competent Starcom agent who can help with complex installations. You can contact Tony (Bray Comms Ph: 01-2865471) and mention that Rob Syme sent you via me. How's that for lack of bias! Link to comment
LGannon Posted March 26, 2007 Author Share Posted March 26, 2007 Thanks John I think I'll go with the Autocom as its about half the cost of the starcom, I just need to figure out how to get line level out of my radio, I was't concerned about installation either way, cheers Link to comment
John Bentall Posted March 26, 2007 Share Posted March 26, 2007 Les, it should not be necessary to figure that out. Autocom make a cable, part #1321, which takes a feed from the on-board speakers, adds a interference-reducing isolator and some "resistance" to reduce the current down to line level and then plugs into the Autocom. I had this done successfully to my R1100RT which has basically the same radio. Link to comment
