Chugger Posted March 24, 2007 Share Posted March 24, 2007 Just replaced my front tire for the first time. And now I'm having trouble with the rear wheel. I removered the calipers and then the 4 bolts but the wheel does not want to budge. Any Ideas Thanks Chugger Link to comment
Vavaros Posted March 24, 2007 Share Posted March 24, 2007 Try tapping the wheel with a rubber hammer and a soft cloth on and it will be ok... Link to comment
Chugger Posted March 24, 2007 Author Share Posted March 24, 2007 It seems to be frozen on any suggestions? BFH Works Link to comment
SMD Posted March 24, 2007 Share Posted March 24, 2007 Unless there is a difference between the 1100RT wheel and the 1150RT wheel, the only bolts needing to be removed are under the plastic wheel center cap. I've never found removing the brake caliper bolts necessary. Once the wheel lug bolts are removed, a good side kick should release the wheel. Probably ought to put a long screwdriver or other object in the center stand lock before banging away too much. Link to comment
Huzband Posted March 24, 2007 Share Posted March 24, 2007 How many miles are on the bike? And, how long since it was last removed? Time takes a toll. Tap it firmly as you rotate it,& it should break lose. Don't worry. You won't hurt anything. In response to SMD, there is no plastic center cap on the 1150. And, you must remove the caliper to dismount the rear wheel. Link to comment
Boffin Posted March 24, 2007 Share Posted March 24, 2007 Unless there is a difference between the 1100RT wheel and the 1150RT wheel, the only bolts needing to be removed are under the plastic wheel center cap. I've never found removing the brake caliper bolts necessary. Once the wheel lug bolts are removed, a good side kick should release the wheel. Probably ought to put a long screwdriver or other object in the center stand lock before banging away too much. On the 1100 the brake rotor is mounted to the final drive. On the 1150 it is mounted to the wheel and so the caliper need removing. Then the four wheel bolts. If stuck, try some WD40 or better still plusgas, into the lug bolt holes and wheel centre, leave for a half hour then using a soft hammer hit the wheel firmly close to the centre. Andy Link to comment
Chugger Posted March 25, 2007 Author Share Posted March 25, 2007 Thanks Gentlemen, Spraying liquid wrench into the bolt holes waiting for 30 min. and then using a block of white oak and framing hammer seamed to do the trick. Link to comment
