Tucker2930 Posted March 23, 2007 Share Posted March 23, 2007 Riding home from my 6000 mile service now the gear indicator now won't show "N" when in neutral. Just black where the letter should be. Also showed "5" when in sixth gear then switched to "6" after 2 miles. Any answers for this would be appricated. Link to comment
riding4work Posted March 23, 2007 Share Posted March 23, 2007 Similar thing happened to me. Neutral green light and the "N" indicator didn't come on one day and wouldn't start in neutral. All the gear indicators worked ok. Stayed that way for about 2k. At the 6000 mile service the dealer found a fault code and reset it. Everythings been fine since. Link to comment
AdventurePoser Posted March 23, 2007 Share Posted March 23, 2007 I noticed on your page that you "don't want me knocking on your door." What are ya? A girl scout selling cookies?? Steve ps-I have a fault on mine telling me I'm low on oil. This will be the second fault code reset in as many months. Link to comment
loujack Posted March 23, 2007 Share Posted March 23, 2007 I had a similar problem just before my 600 mile service where the shift indicator would not display N and it was blacked out. in addition, the indicator didnt work when stopped (but in gear) but worked when underway. In addition - the green N light wasnt working either. Turned out to be a loose sensor plug. The dealer pushed it til it "clicked", did the wear in service and it's been fine for 10,000 miles. Link to comment
Tucker2930 Posted March 23, 2007 Author Share Posted March 23, 2007 Thanks and I will look for that before the trip to the dealer. Link to comment
Leo Flor Posted March 23, 2007 Share Posted March 23, 2007 Can you tell where that sensor plug is, please? That would be the first thing to check if I encounter the same symptoms...the the RT, that is. Link to comment
Ken H. Posted March 24, 2007 Share Posted March 24, 2007 Can you tell where that sensor plug is, please? That would be the first thing to check if I encounter the same symptoms...the the RT, that is. The sensor, actually a variable rheostat, is located on the rear of the transmission, kind of toward the left side. Trace its wiring back into the bike from there. Link to comment
Tucker2930 Posted March 24, 2007 Author Share Posted March 24, 2007 Checked plug for variable rheostat and found OK. Dropped bike off at dealer this morning. Thanks for the info. Link to comment
