Peter W Posted March 17, 2007 Share Posted March 17, 2007 ...what size allen wrench is needed to take off the transmission drain plug on a 2000 K12RS? Anyone? Anyone? Bueller? My Clymer's won't tell. Thanks in advance. Pete Link to comment
ShovelStrokeEd Posted March 17, 2007 Share Posted March 17, 2007 12 or 14mm probably. Buy one of each, but get good ones. This is NOT the place you want a sloppy fit. I tap mine up into the hole after blowing it out with compressed air to make sure it is fully seated and then apply the persuader du jour. Years ago, I had some quality hex wrenches that I cut down to about 1.5" long with a zizz wheel. I use these with standard 6 point sockets instead of using a hex socket set. Link to comment
Peter W Posted March 17, 2007 Author Share Posted March 17, 2007 Thanks. Can't be 12mm since I special ordered one of those a while back and it's too small. I'll order a 14mm and see if it fits. Link to comment
ESokoloff Posted March 18, 2007 Share Posted March 18, 2007 On the advice of our own ELP-JC I picked up a cheepy allen socket 3 pack (12, 14, 16mm?) from Auto Zone. Note that I have a 03GT so I don't know if 14mm is the size you need. Link to comment
ShovelStrokeEd Posted March 18, 2007 Share Posted March 18, 2007 Real quick and easy check. Take a 3/8" hex head cap screw and try to put it in the hole. The distance across the flats is 9/16" which is very close to 14mm. Don't get clever, it is actually not a perfect fit. Ditto BTW, for 12 and 16. A 5/16 HHCS will want to go into the 12mm but just won't, quite, and a 1/2" HHCS, which has a 5/8" head will be a similar fit in a 16mm. For you guys who started to bugger the 14mm, 9/16 is actually 1/4mm larger and can probably be driven in there. Link to comment
Peter W Posted March 18, 2007 Author Share Posted March 18, 2007 It is 14mm. Got the cheapo socket set (12, 14, 17mm) at Autozone and it worked. Thanks all! Link to comment
James Clark Posted March 21, 2007 Share Posted March 21, 2007 . . . and a 1/2" HHCS, which has a 5/8" head will be a similar fit in a 16mm. 3/4" (approximately 19mm) is the standard hex size for a 1/2" screw. Link to comment
