BrianT Posted March 17, 2007 Share Posted March 17, 2007 I traded in the 03 GT on a new 07 GT today. I had been using a Bigmak tank bag on the old GT. When I tried to transfer it over to the new GT it's mounted too far forward preventing the handlbars from turning much. My question is did anyone else have this same problem? If so, were you able to fix it by getting a new mount bracket from Bigmak to use with the old bag, or do you think I need a new bag as well. I'm not sure which version bag it is I have, but I think its the Bigmak Stealth SC or TC. Also, am I reading the manual right that during the break in miles I only need to keep the RPM's under 7k and not the usual 4k? Link to comment
BMKrider Posted March 17, 2007 Share Posted March 17, 2007 Also, am I reading the manual right that during the break in miles I only need to keep the RPM's under 7k and not the usual 4k? yep just keep it under 7K rpm for the first 600-1000 miles. No great hardship. Link to comment
Paul Mihalka Posted March 17, 2007 Share Posted March 17, 2007 Congrats on the new bike, Brian! 7.000 rpm break-in it is. With a 10K redline on the GT and 11K redline on the 1200S 7K is reasonable. You can have a lot of fun at 7K Link to comment
RichEdwards Posted March 17, 2007 Share Posted March 17, 2007 I just switched the BigMak bracket from my old RT to my new GT and it fits fine with no handlebar obstruction. You can order a new bracket from BigMak without ordering a new tankbag. Don't worry about keeping the bike under 7K rpm. The new GT will do 100 mph in 6th gear and stay under 7K rpm. Link to comment
MG37221 Posted March 17, 2007 Share Posted March 17, 2007 I just switched the BigMak bracket from my old RT to my new GT and it fits fine with no handlebar obstruction. You can order a new bracket from BigMak without ordering a new tankbag. Don't worry about keeping the bike under 7K rpm. The new GT will do 100 mph in 6th gear and stay under 7K rpm. No problems with my BigMak either. Wait till you see what speeds you can attain after the breakin period I do recommend you vary your RPMS continuously until you get the break in done. Cruising along at a constant engine speed for long distances can cause uneven wear and is less than ideal, IMO, with a new engine. Link to comment
chrisolson Posted March 17, 2007 Share Posted March 17, 2007 ... new mount bracket from Bigmak to use with the old bag an '06 + GT bracket is available. And, yes, you'll have no problems with a self imposed 7K redline during breakin ... it gets reeeeeally interesting later on when you get past that level Link to comment
BrianT Posted March 17, 2007 Author Share Posted March 17, 2007 Thanks for all the replies. 7K limit just seemed too good to be true. Break in will be very fun for a change. Thanks again. Link to comment
