Plasterman Posted March 15, 2007 Posted March 15, 2007 Anyone have any pointers on how to make these easier to install? Thanks Tom
bobbybob Posted March 15, 2007 Posted March 15, 2007 On my 07 R12Rt, I lubed the inside with soapy water and just worked them on bit by bit--took about 5 mins per grip. Push a little, then pull a little--the progress is slow but it works--keep your fingers dry. Note: I ordered the large puppies--I doubt the smaller ones would work that way.
Rocket_Cowboy Posted March 16, 2007 Posted March 16, 2007 I used an air compressor to inflate the grip puppies, so they'd slide right over the grips. Same trick I've used for removing grips on various bikes.
Ken H. Posted March 16, 2007 Posted March 16, 2007 Somebody was talking awhile back about using compressed air to blow them bigger as you work them on. Basically squeezing the end closed around an air nozzle. I've never tried it that way (but I'm going to), but it's an interesting idea.
Jerry Johnston Posted March 16, 2007 Posted March 16, 2007 The air compressor has always worked fo me. It gets the grip about 3/4ths on making the rest easy. I learned it trick from a bicycle shop in 96, so apparently a lot of shops use air to get them on. And you do have to cup your hand around the following edge of the grip to help the grip balloon out.
Carnadero Posted March 16, 2007 Posted March 16, 2007 Soapy water. After about a week or so, the small amount of residual "slipperyness" (is that a valid word?) goes away.
Helga Posted March 17, 2007 Posted March 17, 2007 Okay, so maybe I'm missing something, but what in the world is a Grip Puppy?
Carnadero Posted March 17, 2007 Posted March 17, 2007 Okay, so maybe I'm missing something, but what in the world is a Grip Puppy? This.
