texastopper Posted February 26, 2007 Share Posted February 26, 2007 hello everybody. long time reader first time question asker. i have an 02 rt w/48k miles. first off i would like to say if i may that the people that respond to the questions on this board are very knowledgable and helpful in the dept. of bmw m/c's. thanks in advance. now for the question, at med to high speeds i hear a faint slapping noise coming from the engine area. it sounds simular to an alt. belt that had a small shred ripping off . but its not,removed cover for a visual. any ideas folks. Link to comment
mbelectric Posted February 26, 2007 Share Posted February 26, 2007 Is all the "tupperware" tight? Depress clutch at high speed to lower engine revs to determine whether you have an engine mechanical problem or chassis/body issue. good luck MB> Link to comment
texastopper Posted February 26, 2007 Author Share Posted February 26, 2007 yes it is all screwed down. and all screws are in place, but that is what i thought also , along w/ the thousand other things. Link to comment
E30TECH Posted February 26, 2007 Share Posted February 26, 2007 an exhaust manifold leak can make a popping/slapping sound Link to comment
texastopper Posted February 26, 2007 Author Share Posted February 26, 2007 ok, thanks, i'll check that out Link to comment
ShovelStrokeEd Posted February 26, 2007 Share Posted February 26, 2007 Cam chain tensioner is my bet. Replacement is cheap. Link to comment
