CruisinCruzan Posted February 21, 2007 Share Posted February 21, 2007 If I want to connect my 2610 and Valentine 1 to the same circuit on my fuse block and they both take 1 amp fuses do I use a 1 amp fuse and will I have a problem using them together? Thanks Link to comment
smiller Posted February 21, 2007 Share Posted February 21, 2007 In a perfect world equipment should be fused individually but in this case there should be no problem at all using them both on the same circuit. Use a 2-amp fuse. Link to comment
