jrlunsford Posted February 9, 2007 Share Posted February 9, 2007 I have a new set of Work Shocks on my K12RS but it doesn't have that little knob looking thing that you can adjust and I was wondering does it supposed to have one and can you tell me what their webb site is ? I've just recently purchased the bike and the gentleman had just had these installed. Link to comment
RFW Posted February 9, 2007 Share Posted February 9, 2007 When you do a Google search for "works shocks", the very first item that comes up is the Works website. Well, THAT was hard, wasn't it! It is: http://www.worksperformance.com/ For what it's worth, I have a Works rear shock on my bike, and it is extremely poorly made. Plating is so thin that the thing started rusting after 6 months. Springs do not fit well into the adjuster cup. Not only that, but when I bought it from Works, it arrived leaking oil (porous weld). To get it fixed under warranty, I had to pay for shipping it back to them. On a brand new shock that was not a week old, they had to replace the entire shock body, one of the springs, and some other parts. I will not be buying another Works shock, I can tell you that! Link to comment
Davis Posted February 9, 2007 Share Posted February 9, 2007 Not familiar with their newer shocks but their older models didn't have the infinitely adjustable preload like the stockers. Instead, Works used a lever on the shock body to add or remove an additional spring to switch between solo and two-up loads. http://www.worksperformance.com/ Link to comment
russell_bynum Posted February 9, 2007 Share Posted February 9, 2007 I have a new set of Work Shocks on my K12RS but it doesn't have that little knob looking thing that you can adjust and I was wondering does it supposed to have one and can you tell me what their webb site is ? I've just recently purchased the bike and the gentleman had just had these installed. Works has several different models. Some have the remote preload adjuster just like the stock shock. Some have preload collars that you adjust with a special shock wrench. Some have the preload collar plus an indexed cup that is part of their ARS dual spring setup...you rotate the cup to one of three positions to set the bike for Solo, 2-up, 2-up with luggage, etc. If you give Works a call, they should be able to help you ID what you've got and how to adjust it. FWIW, I had Works shocks (the rear had ARS) on my RT and had zero problems. Build quality was very good, and customer service when I needed rebuilds was also very good. Link to comment
smiller Posted February 9, 2007 Share Posted February 9, 2007 FWIW, I had Works shocks (the rear had ARS) on my RT and had zero problems. Build quality was very good, and customer service when I needed rebuilds was also very good.+1 Works has a few different product lines (some apparently better than others) but the product intended for the BMW oilheads is very well constructed, and the ARS feature (if it's available for your model) is quite clever and effective. Link to comment
tom collins Posted February 10, 2007 Share Posted February 10, 2007 i have had 2 good sets on 2 different bikes (bmws). tom collins Link to comment
