LGannon Posted January 28, 2007 Share Posted January 28, 2007 Is it possible to replace the seal on a side case? when I leave the bike uncovered I get a pool of water in the bottom of the case, only on the left side though ! Link to comment
tomk99r11 Posted January 28, 2007 Share Posted January 28, 2007 I had a leak, think due to carelessly shutting something between the lid and bag. What worked for me was to pull out the rubber seal strip, rotate it slightly and then re-insert in the groove. Hope this works for you. That stuff should be easily substituted I would think. Good luck. Link to comment
Nevets Posted January 29, 2007 Share Posted January 29, 2007 What type cover do you have on the cases? Link to comment
LGannon Posted January 29, 2007 Author Share Posted January 29, 2007 Is there more than one type? Link to comment
Nevets Posted January 29, 2007 Share Posted January 29, 2007 Yes. City (almost flat), regular depth and I'm fairly sure there are also some really deep touring lids. The city/flat lids tend to bend and are almost impossible to seal well, at least for me. Maybe someone could add the correct nomenclature for the lid types. Link to comment
LGannon Posted January 30, 2007 Author Share Posted January 30, 2007 OK, They are not flat, most likely the regular ones. Link to comment
ShovelStrokeEd Posted January 30, 2007 Share Posted January 30, 2007 Easy to tell which is which, just look at your bike from the rear and see what comes to mind. No bags = Michelle Pfeiffer City lids = Lindsey Lohan Regulars = J'lo Touring = Queen Latiffa (?sp) Link to comment
Mark K Posted February 2, 2007 Share Posted February 2, 2007 .......pull out the rubber seal strip, rotate it slightly and then re-insert in the groove....... This worked for me as well (to a degree). Link to comment
