mdjohnson Posted November 17, 2006 Share Posted November 17, 2006 Has anyone seen any retro fit applications of the new electronic cruise control for the newer 1200 models applied to the older models? Thanks. Mark Link to comment
Ken H. Posted November 17, 2006 Share Posted November 17, 2006 The hexhead series cruise gets its speed, clutch, brake and gear selection switches positions, etc. info from the ZFE module. Which doesn't exist on the 1150 series. I believe the adaptation would be impossible. Link to comment
philbytx Posted November 17, 2006 Share Posted November 17, 2006 Sorry...as someone else posted, not available for 1150 motor. Try a Throttlemeister... Link to comment
keithb Posted November 17, 2006 Share Posted November 17, 2006 When I owned my 04 R1150RT I asked the same question about using the R1200 cruise control and was told it cannot be done. I have heard their is an aftermarket cruise control you can buy and install. The cost was about $600-$800 from what I recall. Unfortunately I have no information about the product. Link to comment
Don_Eilenberger Posted November 17, 2006 Share Posted November 17, 2006 Not exactly the same - but the $1.00 "O" ring behind the grip works fine for me.. it can maintain a constant speed on level ground, and takes the effort out of keeping the throttle open. Link to comment
OlGeezer Posted November 17, 2006 Share Posted November 17, 2006 Has anyone seen any retro fit applications of the new electronic cruise control for the newer 1200 models applied to the older models? Thanks. Mark Mark - The first indication that you're on the wrong road is that you reach for the cruise control. If you found a better set of roads, you should eliminate the need. As a rest break for my wrist, I use Bob's wrist rest. Regards, Bill Allen Link to comment
AZgman Posted November 18, 2006 Share Posted November 18, 2006 Has anyone seen any retro fit applications of the new electronic cruise control for the newer 1200 models applied to the older models? Thanks. Mark Some Concours owners use a fairly universal unit from Audiovox. It might work on an 1150RT. http://www.audiovox.com/webapp/wcs/store...tId=&brand= Link to comment
twolfy Posted November 18, 2006 Share Posted November 18, 2006 Mark, Here's one. I know of another one but can't seem to find it right now. www.mccruise.com/ -Tom Link to comment
RSL Posted November 18, 2006 Share Posted November 18, 2006 Here's another vote for the O-ring trick. If you want to go first class, use the John Deere yellow one, for ~$3. Otherwise, your basic black O-ring works just fine. A Throttlerocker is nice, too. That would bring your total outlay to, say, $12-$15. Link to comment
ednap Posted November 18, 2006 Share Posted November 18, 2006 I have the MCCruise fitted to my 01 R1150RT and it is fantastic! Link to comment
mdjohnson Posted November 18, 2006 Author Share Posted November 18, 2006 Tom, Thanks. Link to comment
mdjohnson Posted November 18, 2006 Author Share Posted November 18, 2006 Thanks everyone for your input, and to some of your witty replys. I got a couple of leads. Everyone have a good and safe holiday season. Mark Link to comment
glwestcott Posted November 18, 2006 Share Posted November 18, 2006 Some Concours owners use a fairly universal unit from Audiovox. It might work on an 1150RT. http://www.audiovox.com/webapp/wcs/store...tId=&brand= Here is a link http://www.angelfire.com/il/sproulpage/page13.html to a complete technical description of how to adapt and install an audiovox unit. Link to comment
roydog007 Posted November 18, 2006 Share Posted November 18, 2006 I just move my right hand out about a 1/2' or so onto the the fixed end portion of the grips. That seems to work for me ? Link to comment
photomd Posted November 18, 2006 Share Posted November 18, 2006 I've always wanted to try THIS. I just haven't found the courage. Link to comment
keithb Posted November 18, 2006 Share Posted November 18, 2006 Based on looking at your link wouldn't it be easier just to buy a new bike? Link to comment
1NOTRED Posted November 23, 2006 Share Posted November 23, 2006 I applied a Rostra electronic unit to my '96 R1100RT about 135K miles ago and wouldn't be without it. It took a fair amount of planning and effort, and if doing it again, I'd look hard for a dedicated RT system (there's a unit available from Australia, I recall). Link to comment
Uggles Posted November 24, 2006 Share Posted November 24, 2006 You're right. Check out the sig. Ednap and I did the deal recently and haven't looked back. (Not electronic though) Cheers Link to comment
