Motorradmark Posted November 8, 2006 Share Posted November 8, 2006 Ok. I have a 5pin autocomm pro7 and want to covert my mic to a throat mike for better/clearer transmission. The mics I am looking at all have 1 pin plugs. Does anyone know of an adaptor to connect autocom plug to 1 pin headsets or mics? I thought I remember seeing such a device at the rally in Lima, supporting custom earplug/speakers with single pin plugs. Appreciate the assist and info. s/f Link to comment
James_H Posted March 23, 2007 Share Posted March 23, 2007 Just curious to know if you found out a way to do this. I would like to do the same thing, replace the current autocom mike with a throat mike. Jim Link to comment
UberXY Posted March 23, 2007 Share Posted March 23, 2007 If you decide to do this on your own, Anton has all the wiring diagrams on his website, which is a better Autcom website than Autocom itself. Anton's Autocom Advice Link to comment
EffBee Posted March 23, 2007 Share Posted March 23, 2007 Ok. I have a 5pin autocomm pro7 and want to covert my mic to a throat mike for better/clearer transmission. First, I think you have a conflict in terms. If you have a 5-pin Autocom, it is a Pro-M1 or earlier. If you have a Pro-7, then it is a 7-pin Autocom. Just be sure you get the correct diagram before you start slicin' n' dicin' on the wires. As for throat mics, I've yet to encounter one that works anywhere near as well as the Autocom mic does when properly installed, positioned, adjusted and shielded. Best of luck and please keep us informed. Link to comment
