Chip Posted November 8, 2006 Share Posted November 8, 2006 What is the connecting line and what does it do? I am preparing to replace my alternator belt and HES wiring harness (’96 R1100RT) I’ve removed the dust cover and lower pulley. The book says, “…loosen alternator and pull off belt…” However, I have a connecting line (appears to be made of aluminum) that prevents me from removing the belt. The part number is: 11111341854. I suspect it may contain oil…if so, any tips on how to keep my brand new, expensive, Extended life Mobil One from spilling all over the floor? Link to comment
russell_bynum Posted November 8, 2006 Share Posted November 8, 2006 ?? Where is this line you're talking about? Any chance you could snap a picture and post it? With the lower pulley off, the belt should just slip right off the alternator. Link to comment
kioolt Posted November 8, 2006 Share Posted November 8, 2006 I've never seen the line you're talking about but I have heard that some oilheads have it. I wouldn't worry about losing a lot of oil since it is in such a high spot on the engine. Most of the oil will be in the oil pan. Link to comment
Vincent Posted November 8, 2006 Share Posted November 8, 2006 I've got that piping on my '98. It's some kind of breather tube used on some engines. You won't loose any oil, just remove it and put it back when you change the belt. What bothered me was if I needed to change my alt. belt on the road, I did not have a big enough wrench for that large bolt. I do now just in case I do a road side repair. Good luck! Link to comment
Bprimm Posted November 8, 2006 Share Posted November 8, 2006 What Vincent said. It's a breather/vent tube. Just remove it to replace the belt. Link to comment
Chip Posted November 8, 2006 Author Share Posted November 8, 2006 Here's a pic of the connecting line. The pic is taken from below the telelever. You can see that the pulley is removed; exposing the HES. The top of the connecting line has a banjo bolt. Link to comment
flars Posted November 8, 2006 Share Posted November 8, 2006 It is a breather or vent line. There is nothing inside it. Link to comment
popov1100 Posted November 8, 2006 Share Posted November 8, 2006 hi http://www.xmission.com/~wendell/R1100GS/engine1.html engine ventilation, n° 3 there is oil vapour in this perhaps a little oil is condensing but no problem you can remove it safetly the oil ventilation designe change in 12/1997 http://popov1100.dyndns.org/cpg//displayimage.php?pos=-2863 this engine does not have this parts this 1995 engine have it http://popov1100.dyndns.org/cpg//displayimage.php?pos=-2957 regards Link to comment
popov1100 Posted November 8, 2006 Share Posted November 8, 2006 1995 bloc design http://popov1100.dyndns.org/cpg//displayimage.php?pos=-2980 1998 bloc design http://popov1100.dyndns.org/cpg//displayimage.php?pos=-2981 try the 7 errors game.... Link to comment
bmwmick Posted November 8, 2006 Share Posted November 8, 2006 Jay, It is the Rotary Breather drain pipe. Here is a good place to view it: http://www.realoem.com/bmw/showparts.do?...hg=11&fg=10 Don't worry about oil coming out, it won't. Bookmark this page: http://www.realoem.com/bmw/select.do?vin...0900&arch=0 just enter the last 7 digits of your VIN for a complete parts catalog (ETK). It also gives you the date of manufacture. Mick Tucson Link to comment
Chip Posted November 8, 2006 Author Share Posted November 8, 2006 Thanks to all with their knowledge of the, connecting line...some sort of breather line. It has been removed, no oil so no spill. Am now patiently waiting for my new HES and alternator belt so I can take advantage of this great Houston weather. Man I wish I had another bike Link to comment
