Tommy_Boy Posted November 4, 2006 Share Posted November 4, 2006 Anybody know how thick the lid is on the BMW 49-liter topcase? I want to mount some Bungee Buddies, but don't know if the attached bolt is long enough. Thanks in advance! Link to comment
keithb Posted November 5, 2006 Share Posted November 5, 2006 TB I would be very very careful trying to put BB in your topcase or side cases. The new cases on the RT are hollow (a shell in a shell so to speak). When you attempt to tighten the BB you can crush or crack the inner and outer portion of the bag. By the way the inner portion of a side case costs about $150-$200 to replace. To make it happen you would really need a spacer between the inner and outer portion. I have taken the inner portion of the side case apart (15 screws or so) but not the topcase. It can be done but it is not like drilling a hole through the bags on the earlier model saddle bags, inserting the BB and then tightening it up. Far from it. However the topcase may be easier. I don't know. Link to comment
JustKrusen Posted November 5, 2006 Share Posted November 5, 2006 I put cargo nets in both saddlebags and 49L trunk. I think there was more clearance for the screws in the corners. Link to comment
Rocket_Cowboy Posted November 5, 2006 Share Posted November 5, 2006 I put cargo nets in both saddlebags and 49L trunk. I think there was more clearance for the screws in the corners. Got any pictures of the cargo nets in the saddlebags? I did something similar on my previous bike, but haven't worked that out yet on this one. Link to comment
JustKrusen Posted November 5, 2006 Share Posted November 5, 2006 Trunk using GL1500 Hopnel trunk cargo net. 5 holes drilled by me. Saddlebag door using Hopnel GL1500 saddlebag net. Holes were drilled. Inside saddlebag wall using existing screws. Nets are available from Chrome World. http://www.chromeworld.com/ Link to comment
Rocket_Cowboy Posted November 6, 2006 Share Posted November 6, 2006 Excellent! Thanks Ed. Link to comment
CraCol Posted November 13, 2006 Share Posted November 13, 2006 I put cargo nets in both saddlebags and 49L trunk. I think there was more clearance for the screws in the corners. What type of screws did you use, sheet metal, well nits or other? How long? Thanks, Craig Link to comment
JustKrusen Posted November 13, 2006 Share Posted November 13, 2006 Just short SS sheet metal screws. I used existing screws where possible. Link to comment
