fossil Posted October 24, 2006 Share Posted October 24, 2006 2004 1150 RT with 15K miles has developed an oil leak that when looking up under the bike I see a small drip forming on the bottom of the inside edge of the bracket that the traverse arm is attached to. Nothing wet forward of that point. The trailing area along the drive shaft houseing is not wet, but getting nasty from the dirt collection. I'm 3k away from the interval check so should I wait or park it until I can get it in the shop? Link to comment
philbytx Posted October 24, 2006 Share Posted October 24, 2006 Fossil, This is probably from the breather tube...... Link to comment
fossil Posted October 24, 2006 Author Share Posted October 24, 2006 I see 3 vent tubes paired together nearby but they are dry. Is the breather tube located above the point I'm talking about? I would need to pull off the side panel to see but wondered about the connection between the drive shaft housing and the transmission. Link to comment
philbytx Posted October 24, 2006 Share Posted October 24, 2006 Fossil, Maybe I have the wrong picture in (what's left of ) my mind... Is this drip at the lower (rear diff) end of the drive shaft assembly and not the top part adjacent to the breather tubes? Link to comment
Ken H. Posted October 24, 2006 Share Posted October 24, 2006 I'm not clear about where you are speaking of either. Can you post a picture of what you are seeing? Link to comment
fossil Posted October 25, 2006 Author Share Posted October 25, 2006 That was a bad location description. The drips are forming on the traverse arm connection where it is attached to the bike frame. The three vent hoses nearby are dry. I thought at first it was coming from the bottom of the boot where the drive shaft housing attaches to the final drive. But following the oil and dirt trail forward it leads to this point. The snake in the grass that I overlooked on the first look was the oil contamination of my rear disk rotor. So regardless of where it's coming from I can't continue drive it with half my brakes. Would appreciate your ideas but it is just a used junker to train on. I've got my trusty VTX to drive. Link to comment
redryder Posted October 25, 2006 Share Posted October 25, 2006 " Would appreciate your ideas but it is just a used junker to train on. I've got my trusty VTX to drive" Yeah, I know the feeling. I learned to drive a Viper so I would be prepared for my lifelong dream car, a Vega Link to comment
philbytx Posted October 25, 2006 Share Posted October 25, 2006 Before we get all nervous...let's check the silly ones first..... Does it smell like Hypoid (gearbox) or Engine oil (crankcase breather)? If Hypoid smell: 1. Any trail leading up to the gearbox breather. Gunk on top of the gearbox, running down the side? 2. Leak from gearbox fill/drain plugs? Not so silly, If they are all clean, then it MAY be your output shaft seal but wiser minds might chip in here. Another simple check: If it is none of the above, Decrud your transmission with Simple Green or the like and clean it all off then check your tranny fluid level. Correct fill is with the bike on the centrestand and it is full when it just starts to trickle out of the fill hole. Now, go out for a nice warmup ride and then come back to see if you still have a leak. Again, smell the oil on your rotor, hypoid has that distinct STINK! Starting from the basics.. Link to comment
fossil Posted October 25, 2006 Author Share Posted October 25, 2006 Thanks for reply Phil, Nice organized approach to problem solving. Get back in couple days. To much of a wimp to drive in the rain on purpose for the test drive. Link to comment
philbytx Posted October 25, 2006 Share Posted October 25, 2006 Hey Fossil...you are in TEXAS darn it !!! Rain is a gift..you should be enjoying it !! If I knew I wouldn't get arrested, I would jump on Darth nekkid and ride around in the stuff : but, then again, that nekkid stuff is getting into H-D rider territory . Where's Whip when you need him....? Link to comment
fossil Posted October 26, 2006 Author Share Posted October 26, 2006 PHIL, Your diagnosis plan worked out well. It is transmission fluid leaking out of the boot between the drive shaft housing and the transmission output. (at 15K! you gotta be kidding). I’m grateful for this early experience and to the others submitting problems encountered with these machines. I bought this bike in May one day after completing the safety course because that was the advice from others. Buy something used to learn on. Having no preconceived notion as to reliability I can see where a person could fall in love with these machines but BMW motorcycles are about status, glitz and glamour, not reliability. I think that reliability sells and that is one of the reasons why BMW sits lower in the market share. Anyway, I’m snake bit. An important step has been taken with my mind being made up. It’s time to cut my losses, dump the bitch and move on to something that doesn’t drip oil on my garage floor or begin my day with a new maintenance issue. I just want to ride. Link to comment
Ken H. Posted October 26, 2006 Share Posted October 26, 2006 It’s time to cut my losses, dump the bitch and move on to something that doesn’t drip oil on my garage floor or begin my day with a new maintenance issue.Seems a bit extreme isn't it? If you like the way the bike rides, your '04 is under warranty, so have the dealer replace the transmission output shaft seal and forget it ever happened. Nothing's perfect. Don't through out the baby with the bath water so to speak. Link to comment
tomk99r11 Posted October 26, 2006 Share Posted October 26, 2006 .....but BMW motorcycles are about status, glitz and glamour, not reliability. I think that reliability sells and that is one of the reasons why BMW sits lower in the market share. You have got to be kidding in this statement, right? You will find high mileage bikes in all brands but I will bet you just about anything you care to wager that none will be as high mileage as BMW. Glitz and status!? Perhaps you are thinking of helping Willie G? Post on the boards a question by brand how many miles owners have ridden their bikes and you will get blown away by BMW mileage, non will in toto come close. Gheez. Link to comment
philbytx Posted October 26, 2006 Share Posted October 26, 2006 Damn, Glad to have been of help but sorry to hear about that.... If it is JUST the seal, then not really a BAD thing just a PITA. If your bike is an 04/04 and not an 03/04 (if you know what I mean), get this checked out and use your warranty. So get to your dealer ASAP!! Please...don't give up on Beamers! Brown stuff do happen sometimes and it happens to all makes... Link to comment
Green RT Posted October 27, 2006 Share Posted October 27, 2006 Would appreciate your ideas but it is just a used junker to train on. Hey Fossil. If a 2005 1150 RT with 15K on the clock is "a used junker to train on", keep me in mind next time you want someone to haul away one of your junkers for you. Link to comment
redryder Posted October 27, 2006 Share Posted October 27, 2006 .....but BMW motorcycles are about status, glitz and glamour, not reliability. I think that reliability sells and that is one of the reasons why BMW sits lower in the market share. You have got to be kidding in this statement, right? You will find high mileage bikes in all brands but I will bet you just about anything you care to wager that none will be as high mileage as BMW. Glitz and status!? Perhaps you are thinking of helping Willie G? Post on the boards a question by brand how many miles owners have ridden their bikes and you will get blown away by BMW mileage, non will in toto come close. Gheez. Well said my friend. I have been riding for 33 years and have NEVER had a bike like my RT. Only bike, or car for that matter, that I liked enough to put 26,000 miles on in just 16 months! Great bike even if it is just an old junker. I'm hoping to get in a few more miles of learning before my moped gets out of the shop. Link to comment
Ken H. Posted October 27, 2006 Share Posted October 27, 2006 Would appreciate your ideas but it is just a used junker to train on. Hey Fossil. If a 2005 1150 RT with 15K on the clock is "a used junker to train on", keep me in mind next time you want someone to haul away one of your junkers for you. Link to comment
