ABS & Battery- Odessey
DR  Major
I just put an Odyssey PC680 into my 1150 GSA (02). It replaced the original acid battery.
I am getting an ABS warning flash now that I didn't get before.
Charged the battery all night and still get the flshhing. Rode the bike for some time with several stops. Still Flashing.
The battery is reading 13.16 volts.
I added lights, Radar, GPS, and horn, but all are on a ignition switched Blue Seas fuse block, so there is no drain w/o the motor running.
Is there an issue with the Odyssey?
Does it have less draw power than the acid battery?
I have used the PC680 on my RT and LT with no problems.
SUGGESTIONS????
I just changed an Odessey after 4 1/2 years because I started to get ABS errors on startup (not enough juice). Before that, had no problems with the Odessey. I have heard sometimes they are defective, you might have to return it. Good luck!
I put a charge on the original battery and put it back in.
I pulled the tank again to look for any obvious dis-connects. Can't see any.
So, I've now had two batteries in - Old w/ charge & New w/ charge. Same results. This leads me to think I disonnceted something while putting the tank back on or adding the wiring for the Autocom and Hella Lights.
Thanks GordanB..!!!!
FOUND IT!!!!! YEA!!
thanks to a link to - http://www.largiader.com/abs/absfault.html
List ABS Fault resetting and it worked 1st time....
FYI--\
Resetting R1150GS ABS2
* Locate the round diagnostic connector on top of the airbox
* With a wire, ground the brown/blue stripe wire (pin #2) and keep it grounded.
* Turn the ignition on
* Hold the ABS button down for about 8 seconds.
* Release the ABS button.
* Turn off the ignition, remove wire.
