bmweerman Posted September 21, 2006 Share Posted September 21, 2006 OK..sorry for the overblown title. Just drained the final for routine matainence before attempting another long trip and it come out looking like this. That looks more like chocalate milk than gear oil to me. Is this something to be concerned about. This is the 3rd final this bike has had on it in 80,000 miles and I'm REALLY paranoid! Thanks! Cameron Link to comment
Lawman Posted September 21, 2006 Share Posted September 21, 2006 I can't figure why there is so much variation in what is being found in the final drives. I've seen everything from oil that looks new to chocolate to metal shavings to torx tools. Sorry... Just did mine (14,200 miles) and it really did not look any worse than the oil I put in it..It did have a somewhat foul odor but other than that it looked great.. Link to comment
bross Posted September 21, 2006 Share Posted September 21, 2006 Wouldn't that color be water contaminated? Just reading about the FD failures on ADVRider and one theory proposed for so many GS failures was water crossings with a hot final drive meeting cool water equals sucking water into the final drive past the seals, causing the problems. Do you wash the bike with a pressure washer? Another theory put forward. Good luck. Link to comment
bmweerman Posted September 21, 2006 Author Share Posted September 21, 2006 Do you wash the bike with a pressure washer? No I don't, but, that's an interesting theory. Things that make you go hmmmmmmmm..... Link to comment
T__ Posted September 21, 2006 Share Posted September 21, 2006 bmweerman, that is interesting.. Mine always comes out about the same color as it went in.. It could be water as that vent cap is not very high above the metal FD casting.. Even washing the bike with a garden hose with a yet warm final drive could suck in water as the cold water cooled the final drive as you sprayed water on it.. I ran into a guy at a meet last summer that had an 1100 RT, he had a hose on his FD vent with an automobile capped vent way up under the seat.. I just happened to be looking at it when the guy walked up (probably thought I was steeling something).. I questioned him on that unique vent set-up & his reply was; he had failed a final drive & when he took it apart there was sand & mud in the bottom of the final drive.. He said he rode a lot of muddy roads & sandy roads so decided he would improve the venting location.. I have no idea how well it worked but to me it looked like a good addition as far as remote venting went.. I know we do a lot of high venting on our off-road trucks.. Twisty Link to comment
bmweerman Posted September 21, 2006 Author Share Posted September 21, 2006 Hmmm...just got pretty much the same reply from some guys at STN... Ok must be water contamination. The question then becomes...is this drive headed for immenent failure? Or is there any way of knowing that? Link to comment
Rob L Posted September 21, 2006 Share Posted September 21, 2006 This is the 3rd final this bike has had on it in 80,000 miles and I'm REALLY paranoid! Do you mean that you have only changed the fluid 3 times in 80k? If so, I would change it much more often. I used to think once a year was enough, now I change the fluid with each oil change at 6000 miles. Link to comment
bmweerman Posted September 21, 2006 Author Share Posted September 21, 2006 This is the 3rd final this bike has had on it in 80,000 miles and I'm REALLY paranoid! Do you mean that you have only changed the fluid 3 times in 80k? If so, I would change it much more often. I used to think once a year was enough, now I change the fluid with each oil change at 6000 miles. No...I mean this is the 3rd DRIVE that has been on the bike. I change the fluid all the time. Link to comment
T__ Posted September 21, 2006 Share Posted September 21, 2006 Hmmm...just got pretty much the same reply from some guys at STN... Ok must be water contamination. The question then becomes...is this drive headed for immenent failure? Or is there any way of knowing that? bmweerman, just make sure your final drive has a magnetic drain plug in it, then change the rear drive oil every couple of months for a while.. If anything sharp shows up on the magnetic drain plug start to worry,, if nothing metallic & sharp on the magnet you are good to go.. If you get a few changes without any metal (excluding gray fine material) you can probably go back to longer drain intervals.. Twisty Link to comment
bross Posted September 21, 2006 Share Posted September 21, 2006 No...I mean this is the 3rd DRIVE that has been on the bike. I change the fluid all the time. Well there's your problem right there! You obviously missed the memo about lifetime FD lubricant being retroactive for older models as well. Link to comment
Guest Posted September 21, 2006 Share Posted September 21, 2006 Looks like way too much fluid to me. Link to comment
bmweerman Posted September 22, 2006 Author Share Posted September 22, 2006 Looks like way too much fluid to me. Hmmmm...have always just filled it to the bottom of the filler hole. Was just looking at the BMW service manual though and it says to do that for the transmission, but not necassarily for the FD...how much do you put in? Link to comment
Davis Posted September 22, 2006 Share Posted September 22, 2006 0.23L or about 8oz, which should be to the bottom of the fill hole. It just looks like more than a cup in your photo, but it may be just we have nothing to put the pool of oil in perspective. Link to comment
opposed Posted September 22, 2006 Share Posted September 22, 2006 ACTUALLY YOU NEED TO FILL IT TO THE BOTTOM OF THE MACHINED AREA BELOW THE THREADS OF THE FILLER CAP. LOOKS BOTH LIKE TOO MUCH AND CONTAMINATED WITH WATER. TOO MUCH IS A BIG NO-NO ON THIS ONE. Link to comment
bmweerman Posted September 22, 2006 Author Share Posted September 22, 2006 0.23L or about 8oz, which should be to the bottom of the fill hole. It just looks like more than a cup in your photo, but it may be just we have nothing to put the pool of oil in perspective. OK ...Thanks! Link to comment
John Moylan Posted September 22, 2006 Share Posted September 22, 2006 ACTUALLY YOU NEED TO FILL IT TO THE BOTTOM OF THE MACHINED AREA BELOW THE THREADS OF THE FILLER CAP. LOOKS BOTH LIKE TOO MUCH AND CONTAMINATED WITH WATER. TOO MUCH IS A BIG NO-NO ON THIS ONE. ...and then subtract enough to stop the little drip from the gaiter....I reckon about 10cc........... Link to comment
FrankT Posted September 23, 2006 Share Posted September 23, 2006 0.23L or about 8oz, which should be to the bottom of the fill hole. It just looks like more than a cup in your photo, but it may be just we have nothing to put the pool of oil in perspective. This has been discussed here in the past greatly. I always measure the prescribed amount when re-filling. The resultant oil level in my rear drive is well below that of the fill plug threads. FWIW...YMMV Link to comment
bmweerman Posted September 23, 2006 Author Share Posted September 23, 2006 0.23L or about 8oz, which should be to the bottom of the fill hole. It just looks like more than a cup in your photo, but it may be just we have nothing to put the pool of oil in perspective. This has been discussed here in the past greatly. I always measure the prescribed amount when re-filling. The resultant oil level in my rear drive is well below that of the fill plug threads. FWIW...YMMV I know! A actually filled the drive 3 times and drove it around a little to clear the fluid. After the last time it came out clear and then I carefully measured 8 ounces into it. I'm trusting that is the right amount. Link to comment
FrankT Posted September 24, 2006 Share Posted September 24, 2006 0.23L or about 8oz, which should be to the bottom of the fill hole. It just looks like more than a cup in your photo, but it may be just we have nothing to put the pool of oil in perspective. This has been discussed here in the past greatly. I always measure the prescribed amount when re-filling. The resultant oil level in my rear drive is well below that of the fill plug threads. FWIW...YMMV I know! A actually filled the drive 3 times and drove it around a little to clear the fluid. After the last time it came out clear and then I carefully measured 8 ounces into it. I'm trusting that is the right amount. 8 oz. is equal to the required 0.23 liters as indicated in a post above so you're ok. Link to comment
