gjnockie Posted September 21, 2006 Share Posted September 21, 2006 I have been reading with much interest the posts concerning the changing of the FD oil in the so called sealed for life FD units. I wonder.. why not drive the bike to heat up the oil and then suck it out? With a good suction pump you should be able to get most of it out? It just seems easier than taking half the bike apart. I used to do this on cars in the 60's since most rear wheel drive cars did not have drains on rear end. Your thoughts and comments would be appreciated. Gjnockie 2005 R1200 RT Boynton Beach Florida Link to comment
Lawman Posted September 21, 2006 Share Posted September 21, 2006 I have been reading with much interest the posts concerning the changing of the FD oil in the so called sealed for life FD units. I wonder.. why not drive the bike to heat up the oil and then suck it out? With a good suction pump you should be able to get most of it out? It just seems easier than taking half the bike apart. I used to do this on cars in the 60's since most rear wheel drive cars did not have drains on rear end. Your thoughts and comments would be appreciated. Gjnockie 2005 R1200 RT Boynton Beach Florida If you do it that way you'll probably miss getting all the torx tools out. Link to comment
steve.foote Posted September 21, 2006 Share Posted September 21, 2006 That's a pretty good idea, Gjnockie. It's possible that there is not enough clearance between the ring gear and the FD housing to get a tube down to the bottom. But, if there is clearance, I can't see any reason why it wouldn't work. It sure would make it a lot easier. Link to comment
Jim VonBaden Posted September 21, 2006 Share Posted September 21, 2006 That's a pretty good idea, Gjnockie. It's possible that there is not enough clearance between the ring gear and the FD housing to get a tube down to the bottom. But, if there is clearance, I can't see any reason why it wouldn't work. It sure would make it a lot easier. Judging by the very slow fill rate, I suspect you would have a hard time getting a tube in far enough. It has even been suggested that you heat the oil before trying to fill the FD. It took me 20 minutes, about, to fill my FD with just .22 liters. Jim Link to comment
IanW Posted September 21, 2006 Share Posted September 21, 2006 I think you will find the normal oil level is above the plug so filling from this plug is not possible. I used a "A" frame and a block and tackle to raise the bike to almost verticle (after removing the amall front mudguard) and drained the oil. It is then a simple matter of removing the muffler and rear wheel and replacing the oil with a syringe through the speedo sensor hole. Ian Link to comment
Jim VonBaden Posted September 21, 2006 Share Posted September 21, 2006 I think you will find the normal oil level is above the plug so filling from this plug is not possible. I used a "A" frame and a block and tackle to raise the bike to almost verticle (after removing the amall front mudguard) and drained the oil. It is then a simple matter of removing the muffler and rear wheel and replacing the oil with a syringe through the speedo sensor hole. Ian Wow, sounds like a scarey way to do it, and one the average person couldn't do at home with regular tools. Notice in this picture that the oil is coming out, and I had not swung the swing arm down yet. Jim Link to comment
MarcS Posted September 22, 2006 Share Posted September 22, 2006 Why would you do it like this, vs, Jim vonBaden's method? Link to comment
IanW Posted September 22, 2006 Share Posted September 22, 2006 Why would you do it like this, vs, Jim vonBaden's method? The brakes and final drive do not need to be touched, it is not as scarry as it sounds if you have the normal gear you would use for removing a car engine, it takes two people, one just holds the bike by the handlebars while it is up. Ian Link to comment
IanW Posted September 22, 2006 Share Posted September 22, 2006 Why would you do it like this, vs, Jim vonBaden's method? When I think a little more the bike may not have to be raised very far in the rear to fill it with the correct amount of oil. Ian Link to comment
