KMG_365 Posted October 20, 2003 Share Posted October 20, 2003 Well, since you've done the hard parts already, the bike is stripped, and the brake fluid can is opened, you might as well take a few more minutes and polish off that hydraulic clutch before you put it all back together. You'll need a 10mmX1.0 SpeedBleeder or another 10mmX1.0 bleed screw from BMW or someplace else. The 1100's use 10mmX1.0's on the front calipers to help your dealer look it up for you. Leslie used a SB as they sent us the wrong sizes for the 1150 and we had two 10mm's left over. You'll also need all the same brake tools (except the Mini-Stan): fresh brake fluid, a 13mm wrench to hold the filler adapter while removing the grub screw, a (5mm?) hex wrench, T-handle or power bit to remove the grub screw and the appropriate sized wrench to install the SB (remember, they still use SAE measurements) or the BMW bleed screw (metric), small wire cutters, and a medium sized zip-tie. ACHTUNG! If you haven't done the brakes already I would read through the other two posts first as there is so much repetition I may abridge some steps here that are important, but similar enough to the other section as to not require restating. Turn the bars so that the clutch fluid reservoir is level and secure the bars. Wrap reservoir with towels, remove the cover and rubber diaphragm clean and set aside. Draw off the old fluid and clean out the reservoir. Top up the reservoir with fresh, clean fluid. Clip the zip-tie on the clutch filler adapter. Peel back the protective sheath and wrap towels around the filler adapter. Remove the grub screw. The filler adapter has a ball check-valve (similar to the SpeedBleeder) which prevents rapid flow when the grub screw is removed. The pointed end on the SB or BleedScrew will push the ball into the adapter, allowing fluid to flow around it. BMW does NOT recommend that the bleed screw be left in place, but the grub screw re-inserted when the bleed is finished. Replace the grub screw with the SpeedBleeder. Connect the tubing and crack the SB 1/4-1/2 a turn. Pump the clutch lever slowly and completely (observe the same technique and especially the cautions as the front control circuit!!!) keeping the blow-by hole covered. Remember: If you are using the BMW bleed screw you will need to close it with each pump before you stop compressing the handle. Since the reservoir and lever are on the left side and the filler adapter is on the right--this is a great example of how the SpeedBleeders help save time and contortions! > When the fluid runs clean, top up the reservior to the fill line, replace and secure the cover and rubber diaphragm, remove the stock BMW BleedScrew and replace the grub screw (or just close and leave the SB in place if you're the "running with scissors" type! ). Clean off the filler adapter well and replace the protective sheath. if using the SB, I recommend cleaning out the end of the SB with compressed air (be careful of splattering!) before replacing the dust cap. I failed to do this for some of my wheel circuits and it looked at first like the SB's were leaking. There can be a lot of fluid trapped in the SB above the check ball. They've all been holding up fine for another 5000 miles now with no seepage (even the SpeedBleeder in the clutch filler adapter). Re-attach the filler adapter to the frame with the new zip-tie and your done! Congratulations on a job well done! Link to comment
BPeterson Posted October 20, 2003 Share Posted October 20, 2003 excellent write up! thanks!! Link to comment
steveknapp Posted April 5, 2004 Share Posted April 5, 2004 Two thoughts. You show putting the bleed screw into the fill adapter with a powerdriver. I found the threads of the fill adapter very easy to strip. Beware. I did it, BMWRich did as well. And hence I learned the other part of this. The fill adapter can be removed. A pair of vicegrips on the fill adapter and a flare nut wrench on the end of the hose and it comes out easily. It can then be replaced with just the bleed-screw, the bleed screw left in, and operated normally. I'll take a pict of what this looks like. Link to comment
rozemab Posted April 5, 2004 Share Posted April 5, 2004 When I tried to use the speedbleeder (2 yrs ago), I could not get the nipple to thread into the checkvalve. TO me it appears the point of the speedbleeder was too 'deep', ie the point was pushing against the checkvalve before the threads engaged. Did the speedbleeder folks create a new nipple with less of a peak? Link to comment
Stan Walker Posted April 5, 2004 Share Posted April 5, 2004 The fill adapter can be removed. Cool, weight reduction, easier than my personal diet. Stan Link to comment
KMG_365 Posted April 5, 2004 Author Share Posted April 5, 2004 Hi rosemab! Actually, I didn't show it in this walkthrough, but we also noticed that the pointy tip of the SB makes it very hard to, A: get the SB centered on that spring-loaded ball check valve while threading it in, and, B: getting enough threads to bite to seal it without stripping. Rick "calikid" posted some great practical observations on his job here. He also illustrates there the same fix we used for this problem. We filed the point off of the SB which solved both problems and used the electric screwdriver with a socket to help hold the SB straight to keep from cross-threading it, while being able to apply enough force to compress the spring pushing the ball check-valve out against the seat. The small electric screwdriver doesn't turn very fast, and I would be VERY careful using it or especially anything larger/faster/more powerful. When we did Steves1150's, we just drug the tip on the concrete to file it down. The SB's are deliberately made of pretty soft metal to be sacrificed before stripping threads (ideally! ) and are supposed to break off before ruining the caliper they are screwed into. If I didn't mention it before, Leslie and I owe a great deal of thanks to "rosemab" and "Maxi-Stan" and the many others who contributed to the excellent threads on this procedure, prior to our posting the walk-throughs! There are also some other good discusions and more helpful info with "lessons learned" from other threads where folks have done their own services (like I never took off the ABS connector when I did my control circuits--what a PITA!). A properly date-ranged and narrowed search should provide even more good info. Thanks again to all of you! Link to comment
steveknapp Posted April 5, 2004 Share Posted April 5, 2004 With regards to the clutch. I was using the BMW OEM bleed screw, not the speed bleeder. I guess my thought is why bother grinding down the tip of your bleed screw, or cross threading it into that soft fill adapter. It's there to make the factory's life easy, not yours. It unscrews easily. What I thought was red loctite was actually thread sealing compound! I had a heat gun all ready to bust that free, no need. Once gone the bleed screw goes right in, all the way. Link to comment
rozemab Posted April 6, 2004 Share Posted April 6, 2004 Hi Jamie, I use SB in all the calipers. For the clutch, I purchased the BMW OEM bleed screw (can't say nipple- gets Stan too excited ) and an 'inline' bleed checkvalve that opens against the hydraulic pressure of the line. Same principle as the SB. You can pick one up at www.whitehorsepress.com (search for bleed), ~$20US. Your posts have been very good for the RT community! Keep up the good work! (Over the past two years I have made several 'mini-Stans' for fellow RT owners/friends in the area.) Link to comment
Cali Kid Posted April 6, 2004 Share Posted April 6, 2004 Jamie & Leslie thanx for the your efforts to provide the great info, your the best. I would like to chime in here and clarify a point (no pun intended ) that we hadn't talked about. ...but we also noticed that the pointy tip of the SB makes it very hard to, A: get the SB centered on that spring-loaded ball check valve while threading it in, and, B: getting enough threads to bite to seal it without stripping. Rick "calikid" posted some great practical observations on his job here. He also illustrates there the same fix we used for this problem. We filed the point off of the SB which solved both problems ... Yes, point one about the tip making it hard to get the speed bleeder(SB) started is quite true. However, I really don't see any way that filing the tip off the SB affects thread engagement. Removing the tip does not give you more thread engagement because the SB is in as far as it will go when it contacts the seat, regardless of how much tip you have left. You can see this when you install a new SB with the tip intact, it will screw in far enough to seal, that's as far as it will ever go tip or no tip, so I'm in doubt that it solves the second problem. The point( ) is to be careful when installing SB's in this application, very high strip potential. For additional reference my pic and notes on the clutch SB are HERE Link to comment
Ken H. Posted April 6, 2004 Share Posted April 6, 2004 Removing the tip does not give you more thread engagement because the SB is in as far as it will go when it contacts the seat, regardless of how much tip you have left. At the risk of adding another voice to this, but having "been there, done that"... The challenge is getting the very pointy SB started because it also has to push in the check ball below it in the bottom of the factory connector as you start threading it. As you attempt to do it the point of the SB moves all over the surface of the metal check ball, which has a very strong spring behind it you are trying to compress, thus making it hard to get a straight square angle on it and started threaded. By grinding the point off you get a better square 'push' on the ball and a fighting chance to get the SB starting threading straight. To put it another way, with the tip as is the SB is basically too long to start threading without also pushing in the check ball at the bottom. And pushing the ball with the pointy SB while keeping it square so as to be able to start threading it in is a very difficult thing to do. So we take the tip off so first the threads start, then a turn or so later in the SB starts to press in the factory check ball. You are correct however that once it is started threading the ground of tip has no effect (good or bad) on the ultimate seal when closed. That seal comes from the tapered sides mating to the fitting. (Presuming you permanently leave the SB in of course.) Link to comment
steveknapp Posted April 6, 2004 Share Posted April 6, 2004 The point( ) is to be careful when installing SB's in this application, very high strip potential See, I'm not just a fool. Remove the fill adapter, other than making this harder than it needs to be to get it threaded in, it serves no other purpose and comes out easily. Link to comment
steveknapp Posted April 7, 2004 Share Posted April 7, 2004 Here's a pict of what the clutch bleed line looks like with that fill adapter removed and the normal bleed screw in it's place. I'd use a speedbleeder instead of the BMW part. But with this setup there are no stripped threads, no ball valve to open, no need to remove anything when you're done. The whole thing works just like any ohter bleed screw. Link to comment
Zip Posted April 7, 2004 Share Posted April 7, 2004 Thanks, everyone. I have been busy cutting and pasting this thread into a document for future reference. The descriptions and pics will come in handy. Link to comment
Ken H. Posted April 7, 2004 Share Posted April 7, 2004 with that fill adapter removed Ah, yes. Missed that idea. Thought about that appoach awhile back, but didn't know if it was the same thread behind the adaptor. Throw the adaptor away = No pushing the ball, point, threading, grinding, etc., song and dance. I like! Link to comment
KMG_365 Posted April 7, 2004 Author Share Posted April 7, 2004 Thanks everyone for your excellent observations! (and Steve, I never thought you were a fool, quite the contrary ). I sure wish I knew before that the filler adapter could simply be removed! Can someone please explain why it is needed over a standard bleedscrew in the first place, please?? I've never seen what the BMW bleed screw looks like, I just assumed it was the same (or similar enough) as the SB. When first trying to thread the SB, I ran into the "engagement without stripping" conundrum as well. I do realize that once sealed the point doesn't matter, but I wasn't sure how far the ball check valve would be allowed to travel in the filler adapter, and I figured with the tip filed off, it would keep the ball from bottoming out on the back of the filler adapter in case the clearance was not sufficient to allow the SB to seat all the way. Heck, from now on, I'll just pull the whole damn thing and save myself some headache! Link to comment
steveknapp Posted April 7, 2004 Share Posted April 7, 2004 I think the fill adapter is just that. It's for filling the system at the factory. Some R1100's had one on one of the front brake calipers as well. People often just removed it. Just to be clear, there is NO need to replace the fill adapter. The speedbleeder, or BMW bleed screw (which is what you see in that pict) seals off just fine. I do think the SB and the BMW screw are pretty much the same thing, both would have the same issues with the fill adapter. I WOULD be sure to use a good flare nut wrench on that hose fitting as not to damage the hose. That and a pair of vise grips is all I needed. I thought I'd need heat, but nope, came right out. Link to comment
co_g30 Posted November 24, 2007 Share Posted November 24, 2007 Here's a pict of what the clutch bleed line looks like with that fill adapter removed and the normal bleed screw in it's place. I'd use a speedbleeder instead of the BMW part. But with this setup there are no stripped threads, no ball valve to open, no need to remove anything when you're done. The whole thing works just like any ohter bleed screw. thanks for the pic, it helped greatly today when I did my own speedbleeder install! Link to comment
Alan Sykes Posted December 8, 2014 Share Posted December 8, 2014 BMW's clutch bleeder....the Werkstück, or as they say in English, the 'factory chunk' on the end of the bleeder hose - another complete rollocks...see the sage, the redoubtable Chris Harris : http://youtu.be/udpZPKoEH50 Otherwise a fab bike of course.... AL in s.e. Spain Link to comment
AndyS Posted December 9, 2014 Share Posted December 9, 2014 Alan you dredged this thread form the grave! Link to comment
Alan Sykes Posted December 21, 2014 Share Posted December 21, 2014 Yes Andy I did, but only because the other week I saw a Spaniard waiting by his bike in the local BMW Stealer's vast workshop whilst the techy was trying to explain to him that the Werkstück is completely redundant as soon as the bike leaves the assembly line in Berlin, but the guy wouldn't believe him ! So there are still riders out there who think that everything that BMW says about or recommends for their bike must be gospel - when often it isn't, because it's done or advised simply because it's cheaper to do so ! And when might I ask did BMW finally admit that a dry clutch on a big powerful bike is less than ideal ? Never ! Only when they redesigned the boxer motor and switched all the new R-models to a WET clutch ! ! Link to comment
Hermes Posted December 22, 2014 Share Posted December 22, 2014 Apocalypse Now music playing in the background: Willard, you had the courage....the courage to simply chuck the Fill Adapter, on a BMW!... the courage.. Link to comment
Alan Sykes Posted February 3, 2015 Share Posted February 3, 2015 Re my posting of the U-Toob link back on Page 2... of Chris H's succinct video on the subject of the pesky Werkstück on the end of the clutch fluid bleed hose...I got the link wrong, so here's the correct page:- http://youtu.be/IrKr1IiOLvk Sorry. Link to comment
