KMG_365 Posted October 16, 2003 Share Posted October 16, 2003 Okay, so you've bled the wheel circuits! Yay! But--the bike is two years old . . . and now you want to do the control circuits. If you've got the tank off already for the wheel circuit bleed or the fuel filter change--you've already done the really hard part! The actual bleeding of the control circuits is fairly easy. There are no calipers to remove and re-install, no brake pads to shim out, no Mini-Stan to deal with, etc. I would still recommend that you read through the entire process here, check out the pics and follow along in the shop manual as well (especially the numbering/sequence of the control circuit bleed screws) to get a feel for the entire scope before proceeding. So, without further ado . . . Leslie and "Arianrhod" proudly present: [cue trumpet fanfare here] Bleeding the Front Control Circuit: :rofl: Remove the dust caps from the six control circuit bleed screws under the tank on the starboard side of the ABS pump housing: Have a 7mm open-end wrench handy for the bleed screws (some might be tightly snugged down and it is a bit of a tight squeeze to get to them, so a longish wrench might be helpful here). The control circuits are bled more like conventional brakes, i.e. not using the servo pump, so you DO NOT turn the bike on for this part (or use a Mighty-Vac). Remember to go easy on the bleed screws (especially the SpeedBleeders). They only take ~7-8Nm to seat and you do not want to snap one off--or worse yet--strip out the hole! The SB's are made to snap off before they strip out the hole. See their helpful website for info on how to remove a snapped-off SpeedBleeder, should the unfortunate happen. First, turn the bars so that the reservoir is level (nearly to full left lock) and secure them somehow so they can't turn back and slosh brake fluid all over whilst you are bleeding. Next, wrap some paper towels or shop rags around the front control circuit reservoir at the right hand grip, then remove the four Phillips screws and remove the cover with rubber diaphragm. You may find that the rubber diaphragm has everted itself. I've been told that this is normal and not a cause for concern--as the pads wear the fluid level drops in the reservoir and can turn the diaphragm inside-out. Just turn it right-side-out again and wipe everything off well with a rag. Be careful not to spill brake fluid on any painted surfaces (it eats paint! ) or get it on your hands (absorption through the skin can be damaging to your kidneys). Also be sure to observe all the warnings and cautions in the BMW shop manual, etc, etc, etc, yada, yada, yada . . . you know the drill! Clean the cover and set it aside. Pump the handbrake lever slowly, but fully to pump any air out of the line (you may see bubbles float to the top of the open reservoir). Be careful that the brake fluid doesn't squirt out of the blow-by bore hole at the bottom of the reservoir--especially later on as the fluid level drops and there is less fluid covering the hole. (Remember that part about brake fluid and paint and your kidneys?) Draw off the old brake fluid with the syringe, then wipe out the reservoir and refill with clean, fresh DOT-4 brake fluid from a sealed container. There is a stepped, raised indexing mark on the forward inside sidewall of the reservoir. Fill the fluid level to this mark and be sure not to let the level drop too far to allow brake fluid to squirt--unchecked--out of the hole in the bottom or allow air to enter the system through that same hole. The six control circuit bleed screws are numbered in a strange skip pattern and the number one screw is bled again at the end of each circuit (i.e. bleed #1, #2, #3, then #1 again to complete that circuit). Refer to the BMW shop manual for the correct numbering of the screws (they are not consecutive) and the proper sequence of bleeding. Basically, you bleed the three (four, actually) front control circuit screws till all bubbles are gone and the fluid runs clear, top the reservoir back off, put the cover back together then do the rear circuit the same way (but the sequence of screws overlap in the correct order of bleeding--don't worry--it will be very clear when you see the diagrams in the shop manual). If you are using the nifty catchment bag from SpeedBleeder.com it makes it harder for air to backflow and enter the system between pumps of the lever(s). Another nifty trick (though certainly not as convenient) is to use some soft silicone hose to go from the bleed screw into a coke bottle or some other such container with a bit of brake fluid in the bottom (submerge the end of the hose in the fluid to help keep the air out of the system). If you are using the SpeedBleeder screws also, it makes it almost impossible for air to get into the system in between pumps and you don't need to be so careful to shut the bleed screw before releasing pressure on the lever(s). But--assuming you're using the stock bleed screws, since SB doesn't yet make the really long 7mmX1.0 (X 2" long!) SB's yet (though I guess you could still use the shorter ones): the procedure is as follows: 1. Set the handbrake lever to position "4" (furthest out) on its adjustment cog. Slowly squeeze the hand brake lever until you hear the brake-light switch click (fluid initially squirts back out the hole in the bottom of the reservoir until the blow-by bore closes). 2. Crack open the bleed screw a quarter to half a turn. You don't have to open it that much--since the system is now under pressure, you'll know when it's open as brake fluid will start coming out the bleed screw--and hopefully into the hose and not all over the ABS housing! 3. Slowly continue to squeeze the lever to the full extent of its travel as the fluid comes out, and then quickly close the bleed screw just before you reach the end of lever travel. 4. Slowly release the brake lever. 5. Repeat steps 1-4 until the fluid is clear and bubble-free, from each screw in turn, topping up the reservoir as needed to keep a comfortable amount of fluid over the blow-by bore hole. The mantra you chant whilst doing this is: "squeeze--click" . . . "crack" . . . "squeeeeeeeeze--close" . . . "and release". Easy, huh? It's not rocket surgery or brain science. ("Of course . . . a child could do it . . . a CHILD could do it!" Bonus geek-points awarded for the source of that last quote! ) When finished bleeding the last screw, top up the reservoir to the mark one last time, wipe off the rim, replace the cap with the rubber diaphragm and retaining screws. Then move to the rear control circuit. Bleeding the Rear Control Circuit: The rear is done almost the exact same way as the front. You can access the rear control circuit reservoir behind the black plastic fairing panel. Remove the right side bag, then the panel. Remember to go easy on that plastic pin which can snap off easily! Nifty Beemer Trick #358: a little dab of grease on the rubber grommit or the post will make removal and replacement easier! Remove the cap and rubber diaphragm and wipe them off well. Draw off the old brake fluid and wipe out the reservoir. Refill with clean fluid to the "max" fill line (the raised line in the plastic housing running around the perimeter of the reservoir just above the one that says "min" > ). Follow the same basic steps as above being sure to check the shop manual for the correct sequence of screws to be bled. When you have bled the last screw (actually, the first screw again ), top off the fluid one last time to the "max" mark, and replace the cap, rubber diaphragm and black plastic fairing panel. That's it--You're DONE!!! Go easy on the brakes during the first test ride and until you get used to the new feel. Do some parking lot work (you do anyway, right?? ) and panic stops under controlled conditions to get a feel for the difference. Leslie found out why everyone had been complaining about the 1150's brakes feeling "grabby". She said that hers had felt "mushy" previously in comparison to how they felt after the wheel and control circuit brake bleed. She automatically grabbed the brake with the same force as previously required in a similar situation in a low speed parking lot maneuver and almost dropped the bike when it suddenly came to an abrupt stop. She says the brakes have a MUCH more positive feel to them now. Stay tuned for our next episode: Bleeding the Hydraulic Clutch Circuit! Link to comment
skinny_tom (aka boney) Posted October 16, 2003 Share Posted October 16, 2003 Are you saving this as DIY web pages too? If not, I would like to suggest it. This is gonna come in HANDY! Link to comment
Batsquatch Posted October 16, 2003 Share Posted October 16, 2003 Good job! Thanks for taking the time to document with graphics and helpful hints. Link to comment
Cali Kid Posted December 14, 2003 Share Posted December 14, 2003 ("Of course . . . a child could do it . . . a CHILD could do it!" Bonus geek-points awarded for the source of that last quote! ) Is it too late for the geek points? Bones said it while reattaching Spocks brain! Link to comment
Rider1200RT Posted December 17, 2003 Share Posted December 17, 2003 As a newbie to the 04 RT vs my 70ies RT, I value the info posted here,thanks for the great explanation and pics on this important maintainance endeavor. Link to comment
KMG_365 Posted December 17, 2003 Author Share Posted December 17, 2003 Ding! Ding! Ding!!!!! We have a winner (or loser, as Leslie told me! ;( ) Okay, admit it you were snooping through my SmugMug Site, weren't you?? Link to comment
steveknapp Posted April 5, 2005 Share Posted April 5, 2005 I was digging this up to send to the AMA's reviewer of the R1200RT who said no one can DIY this job. I noticed that you bled the control side without removing the big-black connector next to the bleed nipples. FWIW, removing this connector makes the job a ton easier and has had no negative effect. FYI. Link to comment
KMG_365 Posted April 6, 2005 Author Share Posted April 6, 2005 I noticed that you bled the control side without removing the big-black connector next to the bleed nipples. FWIW, removing this connector makes the job a ton easier and has had no negative effect. FYI. Hi Steve! (Wow! I haven't seen this thread in a while! ) Actually, this was just a first rough version we threw up here just to encourage everyone and guide the folks who had been drinking the BMW corporate Kool-Aid and giving up a trip a year to pay for the dealer to do the brake bleed (or worse, to put it off entirely). We've learned a lot of slick tips and tricks since then from others who have contributed greatly to the body of knowledge. Cali Kid taught me how to take that dang connector off at Roburt's Tech Daze over a year ago. Prior to that, I didn't even know it came off--but it makes a huge difference in accessability! The shop manual specificly states that you need to leave it on, but I don't recall if that was for the control circuits or the wheel circuits. You do need to leave it on for the wheel circuits as then the servos pump the fluid for you (like a built-in Mighty-Vac! ) There was some guy over on ADVrider that did a much more comprehensive illustrated walkthrough with better photos, etc. You might want to forward that one too. Link to comment
SANTA Posted April 9, 2005 Share Posted April 9, 2005 i just finished mine, the hardest part was waiting for the epoxy to dry on the funnel/tube ministan i made. i also used a #3 rubber plug instead of the plastic cover, i couldn't get the adaptor plug from the dealer in edmonton, they had none in stock, just as well they wanted C$65.00. as they say , the cheapest part on a BMW is the the nut behind the wheel.... i also did the clutch circuit, but the grub screw was frozen and i stripped the allen socket head. fortunately the whole dang thing came off and i am probably just going to leave the nipple permanently in place. i did ih without speedbleeders , but a speed bleeder for the clutch would have been so much easier, on all the rest i didn't find it necessary, the 16 daughter provided the leverage at the calipers... and a fine job she did too. Link to comment
John Moylan Posted May 24, 2005 Share Posted May 24, 2005 I've got my bike apart for a different reason, so might as well do mine......question: has anyone seen, or got a pic of BMW part no 3 41 533 - some sort of 'adaptor' ? I already have all the other factory bits, but I'm a bit confused as to whether I can bleed 'against' the pad spreader tool, or that I must have these 'adaptor' thingies........ TIA Link to comment
Blue Beemer Dude Posted May 24, 2005 Share Posted May 24, 2005 If you are referring to the spacers that you put into the calipers... I went to a lot of trouble to make exact replicas of the spacers for the bleed. I also used "speed bleeders" which allowed me to quickly do the wheel circuits without the usual open, squeeze, close, release that one does with standard bleeding. They also prevent any significant pressure to press in the pads, so they (the pads) never moved and the spacers were just a waste of time. I think the only reason that they are recommended is to have the least amount of brake fluid trapped in the calipers. If you just use moderate pressure to bleed the system even without the speedbleeders, I think you'll be OK without them. Assuming, of course, that I'm understanding your question properly... HTH, Michael Link to comment
John Moylan Posted May 24, 2005 Share Posted May 24, 2005 Thanks Micheal. I'm just wondering if, with pistons spread apart with the spec tool, I can just bleed as normal ? - I don't want to damage the tool. I don't know how strong those pumps really are......... Is it a case that you're supposed to spread the pistons, drop in the spacers, and then bleed up against the spacers? The pics in the factory book are next to useless.... Link to comment
steveknapp Posted May 24, 2005 Share Posted May 24, 2005 I didn't use the special tool. I used some wooden shims. When you bleed you open the bleed screw and the pressure is pretty low on the caliper. The self test or the pressure you exert before opening the bleed screw is probably higher, but honestly I didn't think it was that much. Now if you closed the bleed screw and crakened down on the brakes, I could see there being problems. Don't do that. The idea is to push the pistons back to get the fluid out. But also I think they want the pistons in a fixed/known location when you top-up the fluid. I don't think there is any real rocket science here. You can't "bleed like normal" ever. You probably know this. But just to clarify. There is no way fluid you pour into the lever end is going to come out the caliper end. Link to comment
John Moylan Posted May 25, 2005 Share Posted May 25, 2005 ..But just to clarify. There is no way fluid you pour into the lever end is going to come out the caliper end. Gosh, I know that.....but it's been a while since the Tech Daze in GA, but the Aprilia has turned into my ride of choice so the RT is gathering dust.......... Link to comment
