Jim_Lanz Posted September 11, 2006 Share Posted September 11, 2006 OK, You may all know the answer and have most likely provided this info, but here it is anyway. Is there a way to sync my own throttle bodies without going to the dealer? I can handle the valve adjust, fluid changes, brake fluid service, brake pads, wheel removal etc. The TB Sync is not outlined in the manual. Thanks for all your help. Jim Link to comment
Huzband Posted September 11, 2006 Share Posted September 11, 2006 I assume your refering to the 1150. I use a TwinMax, it's a piece of cake. Well, once you get the plastic off. Link to comment
indy Posted September 11, 2006 Share Posted September 11, 2006 OK, You may all know the answer and have most likely provided this info, but here it is anyway. Is there a way to sync my own throttle bodies without going to the dealer? I can handle the valve adjust, fluid changes, brake fluid service, brake pads, wheel removal etc. The TB Sync is not outlined in the manual. Thanks for all your help. Jim 'ere ya go mate. http://www.advrider.com/Wisdom/Wisdom.html Down at the bottom is the TBS for dummies, worked for me. Indy Link to comment
T__ Posted September 11, 2006 Share Posted September 11, 2006 Jim, piece of cake.. The hard part is pulling the plastic off.. With any luck you can usually get by with just pulling the L/H side off as there is an adjustment hole that lines up with the BBS screw going through the R/H side (assuming an RT).. The link you were provided by Indy with will cover the adjustment procedure.. You can even make your own balancing U tube.. I made one (see picture) & all I use is water with a little antifreeze in it for color.. Actually inches of water has a very fine resolution (way better than most Mercury gauges as far a fluid movement per inch of vacuum.. If you balance one side against the other with a water U tube it will extremely close side to side when done.. Twisty Link to comment
hindsight Posted September 12, 2006 Share Posted September 12, 2006 Buy a twin max. It is easy to do and just part of finishing up the Valve Adjustment. In fact, I have never had to adjust the TB's, every valve adjustment I take the bike out to warm it up, throw the twinmax on and the TB's are always spot on. Link to comment
DiggerJim Posted September 12, 2006 Share Posted September 12, 2006 If you don't want to buy your own TwinMax, there's a TechDaze being put together for New England next month and I'll be there (East Granby CT) with mine. I'm going to do a valve adj & TB Sync...and maybe install a Techlusion while I'm at it. You could jump in and use the tools & the experts who will be there too. Jim Link to comment
Jim_Lanz Posted September 13, 2006 Author Share Posted September 13, 2006 Thanks again to all of you. I am going to order the twin max as several of my friends have oil heads and will "benifit" from my experience. Link to comment
