cabbage Posted September 3, 2006 Share Posted September 3, 2006 Hi Have just purchased tomtom rider. Should I wire it to an ignition switched live eg heated seat or should I connect to a permanent live eg battery/accessory wiring. I have heard of some GPS systems rebooting when the supply is interupted by switching off via the ignition. The installation instructions do not provide any help. Regards Cabbage Link to comment
philiph24 Posted September 3, 2006 Share Posted September 3, 2006 I have wired mine direct to the battery on my 1200rt didnt seem to like the canbus system works fine now. Link to comment
h2000fb Posted September 3, 2006 Share Posted September 3, 2006 I have an "05" R1200RT. I connected the power to wires going to auxillery outlet on left side of fairing. Works great. Link to comment
cabbage Posted September 4, 2006 Author Share Posted September 4, 2006 Thanks guys. I have broken into the front heated-seat wiring. This is ignition controlled. The tomtom unit actuates automatically when the ignition is switched on and likewise turns off with the ignition. The unit doesn't reset when turned off at the ignition. I'll update you all when I've used it for a while and let you know of any pros/cons. Thanks Cabbage Link to comment
h2000fb Posted September 5, 2006 Share Posted September 5, 2006 The power also turns off with the ignition switch if you tie into the power outlet. Only it has a short delay before doing so. Link to comment
Wes Posted September 7, 2006 Share Posted September 7, 2006 Apart from the wiring, how do you like the unit? And where'd you mount it? Pics? Link to comment
radark1 Posted September 8, 2006 Share Posted September 8, 2006 I thought the Tom Toms had a battery that lasted for up to 8 hrs.....why worry about hard wiring it? Link to comment
philiph24 Posted September 8, 2006 Share Posted September 8, 2006 pic of tomtom mounted on the front of the tank rails. Link to comment
philiph24 Posted September 8, 2006 Share Posted September 8, 2006 another pic and I agree although i have hardwired my tomtom the unit lasts for about 8 hours on a 2-3 hour charge which is more than enough for most.If you were camping though you might be glad that you had hardwired it. Link to comment
grbrown Posted February 5, 2007 Share Posted February 5, 2007 I thought the Tom Toms had a battery that lasted for up to 8 hrs.....why worry about hard wiring it? Mine won't run for as long as that! On a long trip, such as a holiday/vacation, it would need re-charging, so wiring it in overcomes that. Something less to carry. I make those comments having used it in its cradle, but not yet wired in! Fitting the wiring is a winter job I must get around to soon - on two bikes... Link to comment
AlanBrown Posted February 6, 2007 Share Posted February 6, 2007 I got a TomTom at Xmas, and have been using it for my daily (120 mile round trip) commute. It's a bit of a pain to have to recharge it every night, but once the cold weather eases I am planning to tie into the radio harness wiring, which has both a live and switched live connection. This might mean getting the fairing panels off which I always struggle with, so out of curiosity, how did you route the wiring past the tank? Link to comment
