Charles Elms Posted August 31, 2006 Share Posted August 31, 2006 I decided to change my fuel filter on a 97 R1100RT. No problem changing the filter, it had been changed before by the dealer and they replaced the single use clamps at each end of the filter with reusable clamps. Also the main fuel line clamps on the side of the frame had been replaced. Here is my problem. I need to replace the small diameter gas line clamps(2) that are inside the tank plate. I think they are 8 mm. I have not been able to locate an FI clamps that small. I've tried autozone and Pep Boys. The smallest they have is I believe 11mm and when tightened, the two tabs touch so this size is too large. Can anyone help me out on where to find the small 8 mm fuel injector line clamps? Thanks Link to comment
bmwmick Posted August 31, 2006 Share Posted August 31, 2006 I decided to change my fuel filter on a 97 R1100RT. No problem changing the filter, it had been changed before by the dealer and they replaced the single use clamps at each end of the filter with reusable clamps. Also the main fuel line clamps on the side of the frame had been replaced. Here is my problem. I need to replace the small diameter gas line clamps(2) that are inside the tank plate. I think they are 8 mm. I have not been able to locate an FI clamps that small. I've tried autozone and Pep Boys. The smallest they have is I believe 11mm and when tightened, the two tabs touch so this size is too large. Can anyone help me out on where to find the small 8 mm fuel injector line clamps? Thanks You don't need FI-Class clamps on the small hoses. They are just vent lines, no pressure. Mick Link to comment
SageRider Posted August 31, 2006 Share Posted August 31, 2006 The clamps inside the plate used on the vent hoses will pop open and closed with a small screwdriver and are reusable. Link to comment
Charles Elms Posted August 31, 2006 Author Share Posted August 31, 2006 Thanks for the replies. Talk about can't see the forrest for the trees. I just focused on the clamps and didn't see that they were for the vent lines. I destroyed the clamps when I removed them. I will use small screw type hose clamp. This board is great. Thanks for the help. Link to comment
Jerry Johnston Posted September 1, 2006 Share Posted September 1, 2006 When I changed my gas filter I used zip-ties for the vent tubes. Link to comment
John Dickens Posted September 1, 2006 Share Posted September 1, 2006 I find these useful in non pressure applications (although they are quoted up to 200psi) Link to comment
