BendBill Posted August 27, 2006 Share Posted August 27, 2006 Yep, I'm the dim bulb . . . . . . with turn signal bulb number question. My rear turn signal bulb on right side went out. I was at an independent dealer, who replaced with an 1156 bulb. The next day my other rear bulb fried. I pulled it an noted it is a 1057 [original bulb, I think] I did a search on this site and read that the correct bulb number is 1157. So here's the question: Are all these bulb numbers interchangeable? Thanks. The perplexed want to know. Link to comment
Jerry Johnston Posted August 28, 2006 Share Posted August 28, 2006 The 1157 (same for 1057)is a dual filiment bulb with tail and stop light filiment. The 1156 (same as 1056) are single filiment bulbs. The turn signals only use a single filiment unless yours has been modified (or a 03 is different than a 96)for running and turn signal in which case 1157 will work. My original turn signals came with a german single filiment bulb that say' 12v 37r C2w on it. Link to comment
BendBill Posted August 28, 2006 Author Share Posted August 28, 2006 Thank you Jerry Johnston for the quick reply. I dropped into a local automotive dept for a pair of each and can see the single vs double filament. I wonder if all 2003 models come stock with the dual filament 1057 or if mine was a replacement I don't remember Now to see which works better with my Kisan running lights. I bet I'll stay with the 1156. Link to comment
Ken H. Posted August 28, 2006 Share Posted August 28, 2006 2003 models come stock with the dual filament 1057 They did not. All RTs had single filament front and rear signals from the factory. That's not to say someone hasn't modified it along the way though. Look in the socket. See one 'button' contact at the bottom, or two? That will give you your answer. Link to comment
BendBill Posted August 28, 2006 Author Share Posted August 28, 2006 All RTs had single filament front and rear signals from the factory. Aha! Thanks, Ken H. I think I see the source of my confusion: both my original bulbs are stamped 1057 but they are single filament, not double Link to comment
