rbmw Posted August 21, 2006 Share Posted August 21, 2006 Heres a mystery for someone with a R1100RT parts cat. or someone who has an impressive knowledge of the bike. I have a part from my 96 that I discovered on the garage floor as I was disassembling my bike to get to my clutch. I did not see where the part came from. Can you help me identify it? small round hard black rubber dime sized disk with hole in the middle for a shaft. there is a tiny spring that goes around the circumference of the hole to apply pressure to the shaft when in place. Identification #'s on disk BAFUD 1X27 CFW 3 10 - 22- 6 What is it and where does it go??? Thanks Richard Link to comment
Dances_With_Wiener_Dogs Posted August 22, 2006 Share Posted August 22, 2006 Maybe it's one of them extra parts. Does the bike start and run okay? Don't worry about it! Link to comment
Bart Anderson Posted August 22, 2006 Share Posted August 22, 2006 Sounds like the neutral switch seal, p/n 23311340363. The description from the fiche is "shaft seal (10X22X6)." Note how the dimensions from the fiche match the markings on the part. The seal goes into the neutral switch housing. Link to comment
rbmw Posted August 23, 2006 Author Share Posted August 23, 2006 Sounds like the neutral switch seal, p/n 23311340363. The description from the fiche is "shaft seal (10X22X6)." Note how the dimensions from the fiche match the markings on the part. The seal goes into the neutral switch housing. Bart I think you get the prize. As it turns out My father from whom I bought the bike had ppurchased a new neutral switch but had never put it on the bike. I had the part out looking at it and he must have also had a replacement seal in the bag that dropped out onto the floor without me noticing. thanks a bunch Link to comment
