scottie_boy Posted August 15, 2006 Share Posted August 15, 2006 I'm considering changing the final drive fluid from the Redline I've been using to another brand. In really hot weather after a long run at high speeds, the fluid burps out of the vent and onto the final drive. Yes I understand that this is normal for Redline to do this. Do the other synthetics do this as well? What about fluid compatibility? I don't know if I will be able to remove all the old fluid because it clings to the gears so well. Any recommendations? Just for the record, this technically isn't an oil thread. Link to comment
Urban Surfer Posted August 15, 2006 Share Posted August 15, 2006 I put the redline in mine about 3000 kilometers ago and no burping Link to comment
John Dickens Posted August 15, 2006 Share Posted August 15, 2006 It's the level that's critical here. On level ground top up the rear drive fluid till it just reaches the 'step' at the bottom of the filler plug orifice. Any higher and it will bubble out. Link to comment
scottie_boy Posted August 15, 2006 Author Share Posted August 15, 2006 I don't think that I over serviced it. I'm due for a fluid change. I'll be sure to err toward the low side this time. Link to comment
Paul Mihalka Posted August 15, 2006 Share Posted August 15, 2006 Well, there are not too many Redline oil users and more Redline reports of burping oil out than other oils. So I would guess the type of oil has something to do with it. Overfilling will obviously do it. Link to comment
Tom P Posted August 15, 2006 Share Posted August 15, 2006 I'm on my 2nd change of final drive fluid using redline and paid special attention to not overfill. No burping of fluid...yet. Link to comment
