RobK Posted July 24, 2006 Share Posted July 24, 2006 I just changed the fuel filter on my 00 1100rt and wasn't paying attention to detail when I disconnected the fuel lines between the tank and the plastic fuel distribution lines. After the roasting I deserve, I'd appreciate it if someone can tell me how to identify the correct connections. There are three rigid plastic fuel lines stacked vertically. My assumption is that the high pressure supply line from the pump/filter should connect to the rigid plastic line on the bottom of the three. The top I assume is the return discharge line. Unfortunately the repair manual I have does not show the correct detail. Would the bike run if they were reversed? Link to comment
Jim Moore Posted July 24, 2006 Share Posted July 24, 2006 The bike won't run if they are reversed. Hook 'em up and give it a shot. Link to comment
