Chugger Posted July 20, 2006 Share Posted July 20, 2006 Had the bike shipped and the shipper damaged the antenna and base. I know the left side will need to be removed to get to the radio box. Not sure what else needs to come off to get to the Antenna base. Thanks in advance Chugger Blu 02 RT Link to comment
Ken H. Posted July 20, 2006 Share Posted July 20, 2006 If the bike doesn't have the factory speakers, and you have small hands, it is possible to get to the retaining nut on the inside of the front faring that holds the antenna base in place. Also there is a grounding strap running to the frame. Otherwise, especially if the speakers are in place, it's just about easier to remove the front faring to get to the nut. Link to comment
Yankee_Dog Posted July 20, 2006 Share Posted July 20, 2006 It aint easy. I pulled my radio box and replaced it with the larger box from a R1100RT available from the Beemer Boneyard. That parts was easy. The 1100 box is a direct bolt in replacement and very handy to have. The hard parts was I also pulled my speakers and antenna at the same time. I used a black plug available from your local hardware store to fill in the hole left by the antenna. This guy has some pretty good instruction that I was able to follow. But getting to the antenna and speakers was still a pain. http://arch.home.texas.net/bmw/r1150rt.html Yankee Dog Link to comment
Lyter Posted July 21, 2006 Share Posted July 21, 2006 Chugger, It's not difficult. However it is time consuming. My antenna base broke and I replaced it. I couldn't get to the antenna without removing the front fairing. That means all tupperware comes off, windshield, part of the dash, etc. You really don't have to be "super wrench" to do it. Jack Link to comment
Lyter Posted July 21, 2006 Share Posted July 21, 2006 Paul, Is that you? Bring your bike down this weekend and I'll do it. Jack Link to comment
