ben1364 Posted July 12, 2006 Share Posted July 12, 2006 Any thoughts on where to mount the Sirius Antenna on a R1200RT? I would like to put it on the RCU shelf between the radio receiver and the V-1 but wonder about reception behind/beneath the windscren as well as interference with the two receivers. Link to comment
Tony_K Posted July 12, 2006 Share Posted July 12, 2006 That's a common place. Interference will not be a issue for the most part as the antenna is pulling in not sending out. I have mine attached to the rear side bag basically for aesthetics. I get some signal loss at times especially if we are 2 up but on the open road it's fine. Dense trees or tall buildings cause signal problems no matter where you mount it. Link to comment
Warren_H Posted July 13, 2006 Share Posted July 13, 2006 I have a BMR shelf and placed the antenna on the left of center behind the windscreen. Mounted with 3M grey all weather double sided foam tape. I didn't know if the magnetic base would interfere with the GPS, I called Garmin and they told me the 2610 does not have a magnetic compass. I stuffed the extra wire behind the left mirror. Same as Tony_K tall trees & buildings interrupt the signal, in the same places it's interrupted in the car. Link to comment
azkaisr Posted July 13, 2006 Share Posted July 13, 2006 You can see mine here. Have no issue with it. Kaisr Link to comment
pbbeck Posted July 13, 2006 Share Posted July 13, 2006 You can see mine here right behind the radio. I have the same experience everyone else is having w/ dense foliage and tall buildings, Link to comment
ben1364 Posted July 13, 2006 Author Share Posted July 13, 2006 Thanks guys. I will mount mine on the RCU shelf between the Sirius receiver and the V-1 receiver. Looks like it will be a pretty neat installation, if I do say so! Best to all. Link to comment
