bluepassat Posted July 8, 2006 Share Posted July 8, 2006 Hi i have ordered and got these 3 parts from BMW uk Piston p/n 11 31 7 656 922 Cylinder p/n 11 31 7 688 629 sealing ring p/n 11 9 963 308 http://advwisdom.hogranch.com/Wisdom/CamTensionReplac.html http://www.ebbo.org/stop_the_rattle.php however there is also another part shown that fits between the piston and cylinder [smaller floating piston] (the one where the mans greasing it in the cylinder) my question is do i need this part? (its in one post but not the other?) many thanks Link to comment
BMT Posted July 8, 2006 Share Posted July 8, 2006 The pictures in the ebbo.org link show the current state of play. The modified parts set has been through a couple of iterations: the ADV link has the intermediate version. Don't forget you need a 15 mm combination spanner (ring/open end) to tighten the new part. The old part is 17 mm -- a more commonly found size. Be careful with the air tube o-rings. I had a spare available and I needed it. Link to comment
