Brant Herbert Posted August 26, 2003 Share Posted August 26, 2003 I pulled this out of the other thread. I added some functionality to the registrations Admin page. Mostly putting the results into nice tables, but also some coding changes that will allow me to take some of these reports out the the general population. Soon. Stay tuned for that. Registrations Inspector Link to comment
murrayg Posted August 26, 2003 Share Posted August 26, 2003 Brant, I don't know if anybody has told you this or not, but U da MAN! Link to comment
Jake Posted August 26, 2003 Share Posted August 26, 2003 Brant - I rec'd the below PM from Tasker Day. His registration went through fine. Just an FYI. While registering for the UnRally, I kept getting syntax errors. So, would you mind confirming that you have my info? It is as follows: Tasker Day Link to comment
Brant Herbert Posted August 26, 2003 Author Share Posted August 26, 2003 Yeah, I had added some code Sunday night to try and detect if they were running with JavaScript disabled (some people do that). I discovered one registration that didn't read correctly, and the possibility that someone could submit without having the fields validated caused me some concern. I tested it locally, but managed to NOT upload all the changes. I saw the problem myself last night and fixed it. And in the process I made it so if you submit with a BoardName containing "xxxxxxxx" its taken as a test submission, so I can test changes I might make without adding extra registrations (which I'm unable to delete at the moment). Tasker Day's registration is in there and accurate. I'm gonna work on dressing up some of my reports to offer up as general options next. Link to comment
Tool Posted August 26, 2003 Share Posted August 26, 2003 Oh, I think I stubbed my TOE! First visit looked fine, but I checked back - after registering - and now I get this: ERROR: bad registration data: /var/www/html/unrally/form/attend/data/register-2003-08-26-3f4bebfe9de35.txt -SKIPPED Is it something I did? Maybe my cologne?? Link to comment
Brant Herbert Posted August 27, 2003 Author Share Posted August 27, 2003 Aaaaaaahhhhh!!! I put that feature (the error detection and message) in last night to flag when a registration record (saved in a file) can't be read correctly. Your data is there, its just not being read back correctly. I'll fix that tonight. I've had two other registrations that had the same problem that I edited to fixup. The problem is caused by text entered into the comment boxes; if you hit Enter within that box my code breaks. I will fix this!!!! Link to comment
murrayg Posted August 27, 2003 Share Posted August 27, 2003 Brant, I should've added my wife to my count. She will not be attending any of the planned meals, but will be joining mid morning and staying to mid afternoon. Thanks Link to comment
Brant Herbert Posted August 27, 2003 Author Share Posted August 27, 2003 {scratching head} Guess I've gotta figure out how to programmatically edit the reg. records. David, I got one-time help from Josh on that problem I mentioned, which gave me editability to the registrations *defined at that time*, but newly added records are non-editable. The only way I can "edit", per se, is to write a little script that does a read/modify/write operation, with the script hand-tuned to do the edit job at hand. Summary of the previous problem: I'm unable to edit the registration files from my login account on the server, as the files are created by a different user account ("apache") than the one I'm logged in with, and the accounts have different access rights. Link to comment
Brant Herbert Posted August 28, 2003 Author Share Posted August 28, 2003 Denny, I fixed the problem (fingers crossed) that was causing the error you reported and which was preventing your registration from being counted in the tally. All is well. Now I just need to figure out how to delete duplicates (got one already) and do edits...... Link to comment
Brant Herbert Posted August 28, 2003 Author Share Posted August 28, 2003 Update: 1) I solved the problem of not being able to edit registrations. 2) I fixed Murrayg's registration. 3) I deleted the one duplicate All is well with the world. Mine at least. Link to comment
murrayg Posted August 29, 2003 Share Posted August 29, 2003 Brant, Is the data inspector available for the membership to see? If so I'm not smart enough to find out how to get there through the Unsite. If it is not available do you think it's a good idea for folks to be able to see it? Thanks again for your hard work. Link to comment
Brant Herbert Posted August 29, 2003 Author Share Posted August 29, 2003 No, its not public yet. I'll have it accessible by Saturday with a few links on the Join page, and maybe a link off the "Scoreboard" line on the main page. I need to fine-tune one last report, a listed sorted by state with attendees from that state. Its just a couple minute job, but I haven't got finished it yet. Link to comment
