steve68 Posted June 10 Share Posted June 10 Looking to upgrade my forward lighting set-up for better visibility and illumination. Will be adding hyperlites to the back. I had them in the past, the unit died. Anyone have any faves to recommend? I plan to install myself if possible. Link to comment
wbw6cos Posted June 10 Share Posted June 10 On my RT, I have Clearwater Darlas with amber lense cover, but on my R 1200 C I have https://skenelights.com/ with 2 ambers and 1 white on each side of the fork that are caliper mounted.. The Skene Lights have low current draw which works, for me, better on a 24 year old bike. Link to comment
46nto Posted June 10 Share Posted June 10 Not sure what bike you're riding but I put Denali D3 with dial dim controller mounted to Clearwater mirror mount brackets on my 04 RT. They are great as they are but I'm thinking about putting their yellow lenses in them to be better seen. The pic is the only shot I have of the front of the bike. I made the mistake of trying an LED tail light but it was less bright than the stock bulb so I've got it as an extra in the glove box -oh & it also set off my warning light on the dash. Link to comment
Redfoxx Posted June 11 Share Posted June 11 5 hours ago, 46nto said: Not sure what bike you're riding but I put Denali D3 with dial dim controller mounted to Clearwater mirror mount brackets on my 04 RT. They are great as they are but I'm thinking about putting their yellow lenses in them to be better seen. The pic is the only shot I have of the front of the bike. I made the mistake of trying an LED tail light but it was less bright than the stock bulb so I've got it as an extra in the glove box -oh & it also set off my warning light on the dash. You can put a resistor in the wiring to cause more voltage use so the computer thinks its a normal bulb, but it wont make it brighter. RF 1 Link to comment
steve68 Posted June 11 Author Share Posted June 11 Thanks. I should have mentioned bike in question is 2002 R1150R. Link to comment
Paul De Posted June 11 Share Posted June 11 On my ‘99 R1100RT I replaced the rear brake light bulb with a Kisan Tailbazer. It is brighter than stock and flashes for about 4 seconds before going solid on. Nice part it is plug and play in the OEM taillight bulb socket. The other is a bit of Hawg bling, but did add some functional visibility. They were made by Auto Gem and sold as a pair of led lit jewel license plate bolts. They have a clear jewel lens dominated by red LEDs but have some in the middle of the LED cluster that are a purple color that is supposed to stimulate both your color and B&W vision so they are more noticeable than one would expect. They include a brake light led red boost circuit. Together the Tailblazer and Auto Gems system works pretty well to keep cages off my butt. The aesthetics are minimalist. The Auto Gem jewel lights don’t seem to be available any more. I would still recommend the Kisan Tailblazer though. For the front I had an HID bulb until it died and replace with an LED. The HID actually worked great but the LED bulb I bought has some issues with beam pattern, so no recommendation other than do your homework on the brand of LED bulb to replace your halogen bulb as not all give a good pattern and crisp low beam cut off IMG_5322.MOV Link to comment
Miguel! Posted June 12 Share Posted June 12 Cyclops 10000 LED head lamp. Plug-n-play. Been on my R1000RT for 21 kmiles. No problem with beam pattern. Bright white, not blue. Does have a fan. I’d buy it again. Also Clearwater Darla with yellow lenses mounted to fender bolts. I’d buy these again too. There’s no doubt people see me coming if they are looking my way. Miguel Link to comment
Paul De Posted June 12 Share Posted June 12 Haha, need their solar eclipse glasses to keep from burning out the retinas😎 Link to comment
steve68 Posted June 22 Author Share Posted June 22 Miguel, does this look like the correct cyclops product? https://www.shopbmwmotorcycle.com/products/cyclops-h4-led-headlight-conversion-kit This is another option I found, but seems a bit sketchy... https://www.euromotoelectrics.com/product-p/bulb-h4led.htm Link to comment
Miguel! Posted June 22 Share Posted June 22 2 hours ago, steve68 said: Miguel, does this look like the correct cyclops product? https://www.shopbmwmotorcycle.com/products/cyclops-h4-led-headlight-conversion-kit This is another option I found, but seems a bit sketchy... https://www.euromotoelectrics.com/product-p/bulb-h4led.htm I "think" I still have the box for the cyclops 10000. I'll look and post a picture of it later today. I purchased it from a local independent BMW shop. They recommended it to me and told me they'd been installing them on all the police BMWs - they service the local CHP and municipality BMWs. IIRC, it was $79. Miguel Link to comment
steve68 Posted June 22 Author Share Posted June 22 That would be great Miguel. Thanks for your response. I value a personal recommendation. Is there a Hi and Lo beam on this unit? Link to comment
Miguel! Posted June 22 Share Posted June 22 Yes, There is hi and lo beam. Both hi and low beam consume 35 Watts, so about 1/2 the incandescent H4 bulb. Installation was easy. There is a drive unit that I mounted to frame member that I think holds up the front fairing. You'll see it in the photo below, just below the left turn signal indicator, bars are turned full left to get the photo. It's been installed for 5.5 years, 21,000 miles. Hope that helps. Michael Link to comment
