Bistro Posted April 18 Share Posted April 18 Hi Folks, I'm taking my 2000 R1100RT-P on a 6,000 tour starting next month. Vermont to Taos NM to Boise ID and back through Canada. Spent the winter going over the usual everything, and the bike is running well. I've been riding for 45+ years, and this is the longest trip I've planned. My Questions: What tools do you bring for on the road mishaps? I have tire patch kit, mini compressor, jump start pack, and the standard hand tool kit. What else do you find important? What spare parts would you bring? Any other advice? Thanks! 1 Link to comment
dirtrider Posted April 18 Share Posted April 18 41 minutes ago, Bistro said: Hi Folks, I'm taking my 2000 R1100RT-P on a 6,000 tour starting next month. Vermont to Taos NM to Boise ID and back through Canada. Spent the winter going over the usual everything, and the bike is running well. I've been riding for 45+ years, and this is the longest trip I've planned. My Questions: What tools do you bring for on the road mishaps? I have tire patch kit, mini compressor, jump start pack, and the standard hand tool kit. What else do you find important? What spare parts would you bring? Any other advice? Thanks! Afternoon Bistro You might take an HES as those are probably not in stock in most areas. Are your brake hoses replaced? If not then you should probably replace those before your trip. Back when I was traveling long distance on the 1100 or 1150 I didn't take much with me but I had things like HES, final drive crown bearing, throttle cable, etc at home & labeled so it could be quickly over-nighted to me if needed. I did carry a long lightweight tow strap, homemade lightweight jumper cables (now would carry a small starter pack), On the air pump, again light weight, small 12v compressor with the housing removed to make much smaller & the hose shorted (to store easier) & the wires lengthened to allow the pump to get out to the wheels (easire to pack with a short hose but longer smaller wires). Definitely carry some replacement fuses & a small 12v test light (or a small voltameter), Wind some tape on a pencil & wind some mechanics wire on that same pencil, Take some zip ties, A small forehead type light is also a BIG plus if you have problems at night like a flat tire or other issue, I had a homemade tire patch kit so hopefully someone else can tell you what they carry as a store bought patch kit. Added: I forgot in the above but a small (not full sized) pair of vise grips is a great (fit-all/ do-all) type tool as it can become a shift lever, or a clutch lever, or a hose pinch-off, or a wrench, or clamp. Find all the BMW dealers that will along (or close to) your route complete with phone numbers & hours. You could Google them but a quick list is nice if at night or frustrated. A credit card & a cell phone is probably your best choice of tools to take. The common thing in the above are "light weight" & "small". Actually the very best thing that you can take with you is a fellow 2nd rider as they can tow you, or go for parts or go for help, plus keep a cool head when you are frustrated & don't. 4 Link to comment
DBULL Posted April 18 Share Posted April 18 Sounds like a great ride! You don't say how long you are planning to take for the ride? You won't need an oil change, so don't need filter or oil, and if it gets low, you can easily get oil I have a new to me 2019 R1250RT, and last year, I replaced both tires, brakes, oil, final drive, etc- Whatever tools I needed to do these simple repairs I set aside and that is now what I carry. If something more serious happens, I have AAA for a tow. I know some folks take their whole shop with them. My left side pannier is my tool kit/tire kit, bike cover, first aid kit. I hope to never open it on the trips I take (this week WI-WV, VA, TN, KY). My top case is too many pair of gloves, windshield cleaner, cleaning cloths, snacks, papers/registration/instructions for GPS and Clearwater lights. Right pannier is a small bag for clothes. I travel lightly. I don't care for extra bags on the bike, but I haven't camped for 50 years, and not starting now. Less to bring, is less to lose and take care of along the way. Enjoy the ride. 3 Link to comment
RPG Posted April 18 Share Posted April 18 19 minutes ago, Bistro said: Hi Folks, I'm taking my 2000 R1100RT-P on a 6,000 tour starting next month. Vermont to Taos NM to Boise ID and back through Canada. Spent the winter going over the usual everything, and the bike is running well. I've been riding for 45+ years, and this is the longest trip I've planned. My Questions: What tools do you bring for on the road mishaps? I have tire patch kit, mini compressor, jump start pack, and the standard hand tool kit. What else do you find important? What spare parts would you bring? Any other advice? Thanks! Adding to D.R.'s excellent advice (135k on my 2004 RT) various size zip ties electrical tape various electrical crimp connectors spare 14-16 ga. wire assorted new crush washers Years ago I added a spare oil sight glass and appropriate sized socket, but have failed to need it so far Mini multimeter Spare ignition/saddlebag key The only repair I've had to do recently was for a fellow riding buddy's R90s. The tranny shift lever seal was leaking fairly bad. We removed it and added several wraps of electrical tape to increase the diameter of the shaft. It worked like a charm the rest of the 1500 mile trip. :) Also, check to see your saddlebags are very tight when mounted. As they age, they can get a bit loose and one large bump can send them flying. (ask me how I know). If they're loose, there's several methods to secure them much better using latch pins. Also a good idea to check all the fastening points. You'll have the bags loaded, so you don't want a hidden crack expanding a thousand miles from home. 1 1 Link to comment
Bistro Posted April 18 Author Share Posted April 18 23 minutes ago, dirtrider said: Afternoon Bistro You might take an HES as those are probably not in stock in most areas. Are your brake hoses replaced? If not then you should probably replace those before your trip. Back when I was traveling long distance on the 1100 or 1150 I didn't take much with me but I had things like HES, final drive crown bearing, throttle cable, etc at home & labeled so it could be quickly over-nighted to me if needed. I did carry a long lightweight tow strap, homemade lightweight jumper cables (now would carry a small starter pack), On the hair pump, again light weight, small 12v compressor with the housing removed to make much smaller & the hose shorted (to store easier) & the wires lengthened to allow the pump to get out to the wheels (easire to pack with a short hose but longer smaller wires). Definitely carry some replacement fuses & a small 12v test light (or a small voltameter), Wind some tape on a pencil & wind some mechanics wire on that same pencil, Take some zip ties, A small forehead type light is also a BIG plus if you have problems at night like a flat tire or other issue, I had a homemade tire patch kit so hopefully someone else can tell you what they carry as a store bought patch kit. Added: I forgot in the above but a small (not full sized) pair of vise grips is a great (fit all/ do all) type tool as it can become a shift lever, or a clutch lever, or a hose pinch-off, or a wrench, or clamp. Find all the BMW dealers that will along (or close to) your route complete with phone numbers & hours. You could Google them but a quick list is nice if at night or frustrated. Thanks Dirtrider - all good advice. Yes, brake lines are new SS last year. I also joined BMW MOA, so I have dealers - helpers on the app. Hadn't thought of the vice grips - they saved me many times in my old chopper days! Link to comment
Bistro Posted April 18 Author Share Posted April 18 28 minutes ago, DBULL said: Sounds like a great ride! You don't say how long you are planning to take for the ride? You won't need an oil change, so don't need filter or oil, and if it gets low, you can easily get oil I have a new to me 2019 R1250RT, and last year, I replaced both tires, brakes, oil, final drive, etc- Whatever tools I needed to do these simple repairs I set aside and that is now what I carry. If something more serious happens, I have AAA for a tow. I know some folks take their whole shop with them. My left side pannier is my tool kit/tire kit, bike cover, first aid kit. I hope to never open it on the trips I take (this week WI-WV, VA, TN, KY). My top case is too many pair of gloves, windshield cleaner, cleaning cloths, snacks, papers/registration/instructions for GPS and Clearwater lights. Right pannier is a small bag for clothes. I travel lightly. I don't care for extra bags on the bike, but I haven't camped for 50 years, and not starting now. Less to bring, is less to lose and take care of along the way. Enjoy the ride. Thanks for the comments, DBULL. I'll be leaving Vermont around May 15. Planning mostly state hiways. 5 days or so to Taos to visit my son for a week. 3-4 days following the continental devide up to Boise to visit my daughter for another week. 5-6 days through the northern Midwest into Canada and back home. Figuring 5 or so weeks total. Tools, equipment, rain gear in the panniers, asst gloves, cleaning cloths, whatever in the back box., Small tank bag and a 50 L drybag on the passenger seat. Looking forward to a laid back road trip - ity's been a while! 1 Link to comment
Bistro Posted April 18 Author Share Posted April 18 24 minutes ago, RPG said: Adding to D.R.'s excellent advice (135k on my 2004 RT) various size zip ties electrical tape various electrical crimp connectors spare 14-16 ga. wire assorted new crush washers Years ago I added a spare oil sight glass and appropriate sized socket, but have failed to need it so far Mini multimeter Spare ignition/saddlebag key The only repair I've had to do recently was for a fellow riding buddy's R90s. The tranny shift lever seal was leaking fairly bad. We removed it and added several wraps of electrical tape to increase the diameter of the shaft. It worked like a charm the rest of the 1500 mile trip. :) Also, check to see your saddlebags are very tight when mounted. As they age, they can get a bit loose and one large bump can send them flying. (ask me how I know). If they're loose, there's several methods to secure them much better using latch pins. Also a good idea to check all the fastening points. You'll have the bags loaded, so you don't want a hidden crack expanding a thousand miles from home. Thanks RPG, all good advice. Link to comment
DBULL Posted April 18 Share Posted April 18 8 minutes ago, Bistro said: Thanks for the comments, DBULL. I'll be leaving Vermont around May 15. Planning mostly state hiways. 5 days or so to Taos to visit my son for a week. 3-4 days following the continental devide up to Boise to visit my daughter for another week. 5-6 days through the northern Midwest into Canada and back home. Figuring 5 or so weeks total. Tools, equipment, rain gear in the panniers, asst gloves, cleaning cloths, whatever in the back box., Small tank bag and a 50 L drybag on the passenger seat. Looking forward to a laid back road trip - ity's been a while! You're going to see some amazing things, and you are wise in taking this much time. Looking forward to hearing about the trip. 1 Link to comment
Jim Moore Posted April 18 Share Posted April 18 I'd carry a HES, a fuel filter, an alternator belt, and a full set of cables. I'd have all the tools I needed to change them. I'd have a way to plug and inflate a tire. I'd zip-tie a set of spare keys to a hidden spot on the frame. I'd have a starter and a driveshaft packed up and ready to ship. Maybe a set of levers, in case you drop the bike? 1 1 Link to comment
Hosstage Posted April 18 Share Posted April 18 Meds. Medical insurance card. AAA with premium or RV coverage. Credit card(s). Cell phone. The other kit listed above. Spare keys are a really good idea. Patience when it may not be a good time to ride due to weather or health (mental or otherwise). Good luck and have fun, I'm a little jealous! 3 1 Link to comment
King Herald Posted April 19 Share Posted April 19 For a long time I carried enough tools to pretty much strip my bike down to the ground, but only the tools I needed, the right sized sockets, a 3/8 ratchet drive, Allen keys, certain wrenches, an adjustable, plus a small bottle filled with various nuts, bolts, hose clips, some wire, and some crimp on fittings, a puncture kit, electric compressor, etc. In 70,000 miles on this bike I’ve only ever broken down twice, and both times I had to be trailered home. And both times I was but ten miles from home. First one was HES failure, second time was my left side cam tensioner came loose, spewing enough oil out to trigger the low oil pressure light. I’d swapped the upgraded version in 8000 miles previously and it had somehow worked loose, very suddenly. In theory I could have fixed the tensioner problem, but it was dark, I was at the side of a busy road, I couldn’t see where the leak was actually from, and I had no spare oil anyway. Nowadays I carry just a bare minimum of tools, but if I go touring again I’ll sort out my full kit. 2 Link to comment
BamaJohn Posted April 19 Share Posted April 19 Wishing for you safe travels and tailwinds. 1 1 Link to comment
lukaspriest Posted April 19 Share Posted April 19 I perked up when you mentioned you were coming through my hometown of Boise........I saw you plan on heading up north from there to Canada. I hear that riding the "Lolo Pass" (From Kooskia, Idaho to Lolo, Montana) is one of the most incredible rides you can take on a motorcycle. It's at the top of my priority list once I get my '94 RS upgraded with stainless steel brake lines this next week. If you have any mechanical problems while you're in the Boise area, I have lots of tools you can use. I wish you safe travels! 1 Link to comment
Bistro Posted April 19 Author Share Posted April 19 1 hour ago, lukaspriest said: I perked up when you mentioned you were coming through my hometown of Boise........I saw you plan on heading up north from there to Canada. I hear that riding the "Lolo Pass" (From Kooskia, Idaho to Lolo, Montana) is one of the most incredible rides you can take on a motorcycle. It's at the top of my priority list once I get my '94 RS upgraded with stainless steel brake lines this next week. If you have any mechanical problems while you're in the Boise area, I have lots of tools you can use. I wish you safe travels! Thanks lukaspriest! My daughter lives in Eagle, her husband rides a K75 that he's had for decades. I've been over Lolo pass, back in the 80's, it's a sweet ride. As I came over the pass into Montana I came across a mother bear and her 2 cubs in the middle of the road. An eye opener for sure. Hope you have many happy miles on the RS. 1 Link to comment
Red Posted April 20 Share Posted April 20 Join BMW Motorcyclists of America. Get your BMW Anonymous book The Anonymous Book - BMW Motorcycle Owners of America (bmwmoa.org) It has all the dealers nation wide and at least a thousand bmw riders listed all across the US that will come to your rescue with a phone call. 1 Link to comment
Bistro Posted April 20 Author Share Posted April 20 29 minutes ago, Red said: Join BMW Motorcyclists of America. Get your BMW Anonymous book The Anonymous Book - BMW Motorcycle Owners of America (bmwmoa.org) It has all the dealers nation wide and at least a thousand bmw riders listed all across the US that will come to your rescue with a phone call. Thanks Red, joined MOA last month - got the app... 1 Link to comment
Shane J. Posted April 22 Share Posted April 22 I carry the same tool kit I use at home. Has everything I need short of removing transmission or swingarm. It's still a small rollup. This has saved me many times. Most important to be able to remove the bodywork. If it's not a tool I use regularly it won't be in the kit. This also matches your tool kit to your mechanical abilities. 1 Link to comment
King Herald Posted April 22 Share Posted April 22 This was how I carried my tools on the bike, bought it on ebay I think. It can roll up nice and tight, and can be hung from the handlebar when you use it, or laid out on the floor. Good solid construction too. 3 Link to comment
Bumwah Posted May 1 Share Posted May 1 I’ve put a few miles on BMWs and I’ve needed Water and Jerky much more than tools or oil. Just do the best preparation you can and enjoy the ride. I carry a roll of tp not a toilet… 2 Link to comment
Bistro Posted May 2 Author Share Posted May 2 Thanks Bumwah. I think I've got it down to the essentials. Y'know, I did a lot of cross country hitchhiking way back in the day and learned how to pack what was important. I'm touching into that mindset. Just 2 weeks till I hit the road. Lotsa time, mostly 2 lane state highways, and a bunch of curiosity for what's along the way. Be well, my friend! 2 Link to comment
Bistro Posted May 2 Author Share Posted May 2 Thanks everyone for your input. I'm packing enough to fix a flat, jump start the bike, pull both wheels, change a clutch cable, not get lost, stay dry, cure a headache, hydrate, snack, bandage cuts, listen to tunes, pay for gas, get in and out of Canada, lock up at night, prove who I am, keep my butt clean and teeth healthy. Hopefully I'll stay outa trouble and have great stories to tell. If you get bored you can follow my blog at: https://russrueger.weebly.com/blog---2024-road-trip Cheers! 1 Link to comment
Redfoxx Posted May 2 Share Posted May 2 3 hours ago, Bistro said: Thanks everyone for your input. I'm packing enough to fix a flat, jump start the bike, pull both wheels, change a clutch cable, not get lost, stay dry, cure a headache, hydrate, snack, bandage cuts, listen to tunes, pay for gas, get in and out of Canada, lock up at night, prove who I am, keep my butt clean and teeth healthy. Hopefully I'll stay outa trouble and have great stories to tell. If you get bored you can follow my blog at: https://russrueger.weebly.com/blog---2024-road-trip Cheers! Sun block, wet wipes (muti purpose, clean hands from working on bike or personal care :-) ) Many areas of Canada are very rural. 2 Link to comment
mickeym3 Posted May 2 Share Posted May 2 You’ll be without cell coverage occasionally….recommend Zoleo Link to comment
Bistro Posted May 2 Author Share Posted May 2 5 minutes ago, mickeym3 said: You’ll be without cell coverage occasionally….recommend Zoleo Thanks mickeym3, haven't heard of Zoleo, will check it out. Link to comment
Darbarian Posted May 2 Share Posted May 2 For years my wife and I used to trip regularly from Kuna, ID to Darby, MT via Craters of the Moon - a boring route, but the one maping software always presented, and that seemed logical enough. I dramatically improved on it by substituting via Garden Valley and mountain highways for the straight stuff. Another improvement opens up on Mapquest when you use Lolo or Missoula, MT as the destination and Eagle, ID as the origin: via Grangeville and the lovely but regularly speed trapped Highway 12 (Valentine One is my co-pilot). Both routes are very nice, just forego the east to Arco, north to Salmon version. https://www.mapquest.com/directions/from/us/idaho/eagle-id-282025431/to/us/montana/lolo-mt-282028218 Have a lovely trip. 1 Link to comment
9Mary7 Posted May 2 Share Posted May 2 13 hours ago, Bistro said: change a clutch cable, Pre-routing a new one by zip tying into the current one will save you a bunch of time and work on the road........ 4 Link to comment
Redfoxx Posted May 2 Share Posted May 2 My bike trip through Canada was via paper map with some gas stop preplanning. Went from Milwaukee, WI, International Falls, east to Québec, south into New York, west along seaway Niagara (US Side) back to Milwaukee. Going east its woods to nothing, to woods and big city. We had a great trip. 1 Link to comment
Dave_in_TX Posted May 2 Share Posted May 2 On 4/18/2024 at 3:23 PM, dirtrider said: On the air pump, again light weight, small 12v compressor with the housing removed to make much smaller & the hose shorted (to store easier) & the wires lengthened to allow the pump to get out to the wheels (easire to pack with a short hose but longer smaller wires). Or if you don't want to hassle with removing the housing from a pump, pumps such as the Motopump from Motopumps, the Motopressor from Rocky Creek Designs, or the Mini Compressor from Desert Fox are already small enough. 1 Link to comment
Dave_in_TX Posted May 2 Share Posted May 2 6 hours ago, Bistro said: Thanks mickeym3, haven't heard of Zoleo, will check it out. A Garmin InReach is an alternative to Zoleo. 1 Link to comment
RK Ryder Posted May 3 Share Posted May 3 Sorry to be late to offering suggestions and I don’t think that I am repeating anything already mentioned other than the jump start battery. Here a number of suggestions, in no particular order of what I find work for me, often learning these tricks from the school of hard knocks. Hope that a few might be helpful for you and ignore the ones that might seem crazy to you. A few small items that I pack for trips are, a small essential first aid kit for myself (or others whom might have needs), a spare set of spark plugs, an extra mouthpiece for my water drinking tube. Candy, gum and/or music for the last hour of the day when you are feeling a bit weary. As mentioned previously, having a battery to jump start your bike change a bad day into a minor inconvenience. Once a relay went bad and drained the battery. I carry a small Jet Boil stove (and in my case 4 litres of water on a pillion footpeg), and coffee. Often a cup of coffee brewed in the middle of nowhere is a nice pick me up. When travelling in bear country, coffee is the only food I carry. At night, the top box is removed from the bike and placed away from the tent and bike. Inside the t. box is placed the coffee, gum, candy, toothpaste, shaving soap and dirty laundry. I’ve had a bear in my campsite once at night but no damage to the tent, bike or the top box. I also carry bear spray, a small air horn, and a decent size camping knife. Fortunately, never had to use them (and I know the result if I had to use the knife.) I normally put high test gas into my bikes but when travelling in remote areas, I have learned to use regular. In remote areas, in the last fill up of the day, I buy and add a small bottle of gas line antifreeze; makes a difference starting the bike in the morning. In the Midwest of both countries, don’t pass a gas station without a top up. The winds of the area can greatly reduce the normal range of your tank. Be certain to add additional coverage for your cell phone for when you are travelling in Canada. Out of country usage can sometimes be very pricey if you do not have additional coverage. Take two wallets and at least two credit cards. The one wallet with the most of the cash and high limit credit card gets packed away in a case. The other one with a low limit and a small amount of case travels in the jacket. Lost the jacket wallet once, quickly cancelled the card and carried on. Don’t know about your AAA coverage but it’s sister company CAA has towing to one destination and will not come back to the motel the next day to continue taking you to your nearest BMW dealer or to your destination. BMW dealerships can be hundreds of miles apart in the Midwest of both countries. For the same money, I now use a RV towing company; if need be, they’ll take you and the bike home or 500 miles to the closet BMW dealer. Maybe take a list of the independent BMW mechanics found on the Internet riders site. https://ibmwr.org/index.php/independent-bmw-mechanics Check that your health insurance will cover you in Canada; if not pay the extra fee for that coverage. First long trip often results in over packing; be prepared, if necessary, to lighten your load by mailing stuff home to yourself. I always take a small empty travel sack and ROK straps. If I find a treasure along the trip, I can strap it across the pillion’s seat or on the rack on my top box if there should not be room in the panniers. Do enjoy the scenic ride through Ontario’s Canadian Shield to the north and Lake Superior to the south of the highway. Stop on the east side of Thunder Bay for a picture of the Terry Fox Statue (a national hero), in Subury for a pic of the bike with the Big Nickel and Wawa with the gargantuan Canadian Goose (which has seen better days). I seldom travel more than 5 kms over the limit up there as moose are quite plentiful. Northern Ontario is very cold in the early morning, even in summer. Warm gloves and warm clothing are necessary for starting your morning ride. For food, stop anywhere except a Tim Hortons. The odd time when desperate and have stop at Tim's, I've regretted it. Fire arms and not allowed into Canada; if you have one leave it at home. Attempting to smuggling one in can result it being confiscated, a fine, a free bed in a cell and deportation. One son, a former custom welcomer to Canada says keep your answers brief. For example “The purpose of your trip? Pleasure.” Only elaborate when asked. Use your credit card for most transactions. However get some Canadian money from your American bank. One does not always get the favourable exchange rate from every Canadian business establishment. Therefore the few times you wish to pay with cash, you will getting full value of your cash. Don’t panic at the higher fuel rates in Canada because by using your credit card, you are effectively getting everything you buy in Canada for approximately a 30% discount. The exchange is that much in your favour! Rather than looking for oil if I should need any on the road, I carry 13oz in a secure water bottle stored in the bike’s cowling. I also pack one glossy magazine. Adding oil with the RT body work in the way is easier if one rips out a glossy centre page, wrap it into a funnel and dispose of it when done. I pack a spare headlight and a couple of bulbs for turn signals and a brake light bulb. Easier than going looking for one if need and they take up little space. When travelling only on the bike, I have found the bike’s tool kit to be adequate. If pulling my small trailer, I have a few more tools, not for my use, but for someone who knows what they doing if their help is needed. I you have a pin lock for your visor, install it before you leave. I ignored mine with helmets for years; big mistake. All my travel clothes are dark; makes for one machine when washing. I pack three wicking shirts rolled up in a kid’s lunch bag and have one long sleeve cotton turtle neck. Don’t know if these are still called “Dickies” which are worn under the neck of shirts which have a piece that wraps around your neck. Take two. They protect your neck from the cold and the hot sun. I carry two cables, each with a lock for those times when I wish to wander around a location, it allows me to lock the riding gear on the bike and other than the boots, looking almost normal. As well, each of my bikes has a plastic covered, short steel cable combination bicycle lock, attached to the right pillion handle. This is used on a regular basis to secure my helmet to the bike where it can rest either on the right pannier or the seat, usually on the pannier. These locks allow me to leave the bike and help keep honest people honest. Have a great ride and possibly write a report of the highlights. Cheers! Paul 2 1 Link to comment
RK Ryder Posted May 3 Share Posted May 3 I forgot to mention that a small compass meant for the dash of a car and paper maps could come in handy if your GPS should have problems. Cheers! 1 Link to comment
King Herald Posted May 3 Share Posted May 3 Something I did when I start touring Europe again was to take photos of my passport, insurances, bike papers, credit cards etc, then email them to myself. If I were to lose everything in a robbery, or through stupidity, as long as I had access to the internet I could get details of what I’d lost. Reporting and replacing lost credit cards is easier when you have access to the emergency phone number and card number that’s on the card. plus you can book a room over the phone if you have the card details. I also stashed a credit card and some cash under the seat of the bike. 3 Link to comment
RK Ryder Posted May 3 Share Posted May 3 1 hour ago, King Herald said: Something I did when I start touring Europe again was to take photos of my passport, insurances, bike papers, credit cards etc, then email them to myself. If I were to lose everything in a robbery, or through stupidity, as long as I had access to the internet I could get details of what I’d lost. Reporting and replacing lost credit cards is easier when you have access to the emergency phone number and card number that’s on the card. plus you can book a room over the phone if you have the card details. I also stashed a credit card and some cash under the seat of the bike. Being old school (and a concern of losing my phone), I carry a photocopy of my credit cards, driver’s license, etc in a pouch I’ve installed to the inside of the lid of the top box.. However I never considered copying the passport or insurance cards; great idea. 👍 2 Link to comment
Lowndes Posted May 3 Share Posted May 3 I've carried one of these with the tools for several years, has come in handy several times for me and others for testing batteries, circuits, bulbs, etc. Inexpensive, very light, and small. https://www.amazon.com/gp/product/B000JFNURG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 You might want to carry an extra bulb for the headlights, blinkers, brake/tail lights. Also, a couple of small plastic bottles with engine oil and final drive oil so that you have the right stuff if necessary. Did you replace the internal fuel hoses and the plastic fuel hose quick disconnect?? On your RT the battery is such a PITA to get to, to connect jumper cables, an air pump, etc, you might consider either an SAE connector (like a two pole trickle charger connection below). Make sure your air pump has the same connector. Not really good for jump starting the bike with cables or jumper packs as these little wires tend to glow and smell bad. Or, heavier battery terminal extenders that can be reached by just removing the front seat. See a thread on this forum: Jump starting an R1100RT sucks! And, AMHIK. 1 Link to comment
DBULL Posted May 11 Share Posted May 11 I've appreciated all these responses and ideas for travel. I leave for 3 weeks on the bike middle of June. Solo from WI to Hyder Alaska, put my tire in Hyder and head down to Seattle to pick up my wife at the airport. We ride WA state for 8 days, then she flies home and I meander back, via Columbia river, Idaho route 12, Beartooth, Chief Joseph, Powder River pass, and then Iron butt home. We have everything we need on the bike-yes, I love my wife for being a minimalist in packing. The left pannier is hopefully never going to be opened for tools, tire repair. Rain jackets are on the top of that, though, and I'm sure we'll use them. Planning about 6800-7200 miles, depending on how much we ride in WA, so an oil change right before leaving. Tires should be good-1500 miles on them now. This will be my longest trip since 48 state ride in 2016 with a friend, but this will be nicely broken up with the 8 days with my wife. And yes, the hotel accommodations when she is with me are much nicer than when I travel alone! We/I love to look for local restaurants to enjoy another part of the trip. I've been reading/watching Youtube about Hyder/Prince George, but if someone has input for that part of the trip, please share with me. 1 Link to comment
Hosstage Posted May 11 Share Posted May 11 The first long trip with the wife and me, bike is all loaded up ready to go, looked like a pack mule going to the Yukon. As I'm rolling the bike out of the garage, the wife comes out of the house with her full size commercial grade 1800 watt hair dryer and stands there with it in her hands, pushing it toward me. I just look at her. Then I start laughing my ashe off. "What the hell am I supposed to do with that?" She says, "Well, I need it. Put it on the bike." I said "Where? Do you see what we have going on here?" She was not happy. We did not bring the full size commercial grade 1800 watt hair dryer. 2 1 Link to comment
strataj Posted May 11 Share Posted May 11 The first time my wife and I traveled she asked what she could bring. I told her anything she wants. She had that beautiful look of happiness. Then I said but it must fit in here. I did give her the larger case... 2 1 1 Link to comment
John Ranalletta Posted May 11 Share Posted May 11 3 hours ago, strataj said: The first time my wife and I traveled she asked what she could bring. I told her anything she wants. She had that beautiful look of happiness. Then I said but it must fit in here. I did give her the larger case... First and only long trip was from Indy to Gunnison where we rented a Camping Cabin. She We took a pillow and a comforter. Yes. You read that correctly. In the bag. 3 Link to comment
9Mary7 Posted May 11 Share Posted May 11 1 hour ago, John Ranalletta said: First and only long trip was from Indy to Gunnison where we rented a Camping Cabin. She We took a pillow and a comforter. Yes. You read that correctly. In the bag. That is a sweeeeeet lookin' RT John 1 Link to comment
John Ranalletta Posted May 11 Share Posted May 11 Thanks. It was. One of our members made the light brackets for the RT. 1 Link to comment
9Mary7 Posted May 11 Share Posted May 11 2 minutes ago, John Ranalletta said: the light brackets for the RT Looks very similar to the way the pursuit lights were mounted on Authority bikes. 1 Link to comment
Chug Posted May 16 Share Posted May 16 It will be an epic trip, Bistro! Today, with a Wallyworld around every corner, one hardly even need to pack extra Fruit of the Looms! Link to comment
