Redfoxx Posted April 10 Share Posted April 10 Several riders had the same issue that I had the Lock indicator flag was broken off. I bought a BMW kit to repair and got around to it today. It was actually a easy hour long project with taking lots of Photos. It turned out just like new. Link to comment
jascoi Posted April 10 Share Posted April 10 I still haven't been successful in removing the lock cylinder. I bent a paper clip as suggested in another post but I haven't been lucky to get the right release spot yet. wouldn't be surprised at all if I'm doing it wrong. Link to comment
Redfoxx Posted April 10 Author Share Posted April 10 23 minutes ago, jascoi said: I still haven't been successful in removing the lock cylinder. I bent a paper clip as suggested in another post but I haven't been lucky to get the right release spot yet. wouldn't be surprised at all if I'm doing it wrong. It was pretty much straight in the notch, if you look in you will see a flat gold bar, just push in with paper clip. That was the thing that took me the longest since I saw people using bent clips. 1 Link to comment
dirtrider Posted April 10 Share Posted April 10 11 hours ago, jascoi said: I still haven't been successful in removing the lock cylinder. I bent a paper clip as suggested in another post but I haven't been lucky to get the right release spot yet. wouldn't be surprised at all if I'm doing it wrong. Morning jascoi You need to have the key turned to have the lower retaining wafer line up with the hole that the paper clip goes into. (this retracts all except the lower locking wafer). See upper & lower red arrows showing direction. You need to feel around a little with the paper clip until you find the spring pressure of the lower retaining wafer (you MUST depress that lower retaining wafer against the spring before the lock cylinder will come out. (lower red arrow) If you have some key wear, or a loose fitting key, you sometimes need to wiggle the key or pull the key up & down very slightly to get all the locking wafers to fully retract. See blue arrow for one wafer that it not quite fully retracted. Personally I use a little stronger wire than a paper clip (tig welding rod), a paper clip will work but a slightly stronger wire usually works a little better. Modified picture borrowed from Redfoxx's post above. 2 Link to comment
Redfoxx Posted April 10 Author Share Posted April 10 2 hours ago, dirtrider said: Morning jascoi You need to have the key turned to have the lower retaining wafer line up with the hole that the paper clip goes into. (this retracts all except the lower locking wafer). See upper & lower red arrows showing direction. You need to feel around a little with the paper clip until you find the spring pressure of the lower retaining wafer (you MUST depress that lower retaining wafer against the spring before the lock cylinder will come out. (lower red arrow) If you have some key wear, or a loose fitting key, you sometimes need to wiggle the key or pull the key up & down very slightly to get all the locking wafers to fully retract. See blue arrow for one wafer that it not quite fully retracted. Personally I use a little stronger wire than a paper clip (tig welding rod), a paper clip will work but a slightly stronger wire usually works a little better. Modified picture borrowed from Redfoxx's post above. DR I tried a finish nail and was struggling. If I was going to make a tool, I think I would use a small straight screw driver and and curve tip to side slightly. The paper clip was a straight and small enough to push. that spring lock was flush and grease cover to the bottom of the lock assembly. I love the picture I thought it looked familiar. This other picture is one more you can see groove you poke through and the entire parts kit. I didn't think about putting lock insert back in while I had apart. Feel free to use my pictures for educational purposes. RF 1 Link to comment
jascoi Posted April 27 Share Posted April 27 with the information I was able to remove the lock cylinder and rekey it. Ignition key now unlocks the side bag. now i need to find a left bag. a cheap scraped up left one will match the right one. Link to comment
Redfoxx Posted April 28 Author Share Posted April 28 3 hours ago, jascoi said: with the information I was able to remove the lock cylinder and rekey it. Ignition key now unlocks the side bag. now i need to find a left bag. a cheap scraped up left one will match the right one. Glad to help with lock. Cant help with bag. :-) Link to comment
Redfoxx Posted May 15 Author Share Posted May 15 On 4/10/2024 at 5:52 AM, dirtrider said: Morning jascoi You need to have the key turned to have the lower retaining wafer line up with the hole that the paper clip goes into. (this retracts all except the lower locking wafer). See upper & lower red arrows showing direction. You need to feel around a little with the paper clip until you find the spring pressure of the lower retaining wafer (you MUST depress that lower retaining wafer against the spring before the lock cylinder will come out. (lower red arrow) If you have some key wear, or a loose fitting key, you sometimes need to wiggle the key or pull the key up & down very slightly to get all the locking wafers to fully retract. See blue arrow for one wafer that it not quite fully retracted. Personally I use a little stronger wire than a paper clip (tig welding rod), a paper clip will work but a slightly stronger wire usually works a little better. Modified picture borrowed from Redfoxx's post above. DR, I ordered new lock insert, came with set of pins. Coded new one to keys works perfect took old one out of trunk, it was hanging up randomly. Cleaned the grease off and discovered one of the previous owners had filed or dremeled several of the pins? down to make work. Thinking the bike may not have had a trunk possibly when new. I would think a dealer would have the correct pins to re-key since there are only 3 different sizes 1, 2, 3. I ran out of #3s or I would have old lock fixed and keyed as a spare. On to the next project, replacing mirror glass, since one is all scratched from some kind of abuse. RF Link to comment
dirtrider Posted May 15 Share Posted May 15 6 hours ago, Redfoxx said: DR, I ordered new lock insert, came with set of pins. Coded new one to keys works perfect took old one out of trunk, it was hanging up randomly. Cleaned the grease off and discovered one of the previous owners had filed or dremeled several of the pins? down to make work. Thinking the bike may not have had a trunk possibly when new. I would think a dealer would have the correct pins to re-key since there are only 3 different sizes 1, 2, 3. I ran out of #3s or I would have old lock fixed and keyed as a spare. On to the next project, replacing mirror glass, since one is all scratched from some kind of abuse. RF Morning RF That sanding or filing the locking wafers off to re-key (or actually to originally key) used to be common in the auto industry. Especially in applications like glove box locks. I have sanded a few BMW side case wafers to make a used case work with an existing key. I would swap the existing wafers to match the key cuts, then on the remaining ones that were too long just a quick zip of the cylinder on my narrow belt sander to make them flush then all is good. On some of my personal bikes I would remove all but 1 or sometimes 2 wafers (leaving the retention wafer) so I could use about any key depending on how far it was inserted. I would also do the same on the ignition switch. Link to comment
