Bernie Posted April 2 Share Posted April 2 Due to mistakes by the mouse operator and by construction projects unknown to the mouse operator, I had to modify or redo/repair a few routes. This post is to inform every one of which routes have been updated on what date. If you downloaded the routes after that date, you are all set. Don't worry. IF you downloaded the routes before those dates, delete only the original Routes and Tracks listed below. Then download the individual Routes and Tracks, links are below. Reinstall the new versions on your navigation device or app. On 3/31/2024 I updated the following routes: 03 N Lynch KY 138m 03B N Lynch KY 118/256m on 4/01/2024 I updated the following route, due to hidden dirt road: 11A NW Loop 208/318m If more of these problems should happen, I will edit this post. Safe Travels everyone. 7 4 Link to comment
Stresspuppy Posted April 2 Share Posted April 2 @Bernie Thanks! I just loaded 03* and I get a supposed dirt road. It looks to be a short stretch. I'm using Scenic which uses Here maps which may not line up with the Garmin maps, but bringing it up just in case. For 03A: at 36.239759,-83.025980. (03B goes through the same road I think), Magenta outlined road on the map below. Link to comment
Bernie Posted April 2 Author Share Posted April 2 35 minutes ago, Stresspuppy said: @Bernie Thanks! I just loaded 03* and I get a supposed dirt road. It looks to be a short stretch. I'm using Scenic which uses Here maps which may not line up with the Garmin maps, but bringing it up just in case. For 03A: at 36.239759,-83.025980. (03B goes through the same road I think), Magenta outlined road on the map below. Thanks, but it looks paved to me. It was paved back in Sept of 2020. Link to comment
Stresspuppy Posted April 2 Share Posted April 2 1 hour ago, Bernie said: Thanks, but it looks paved to me. It was paved back in Sept of 2020. DOH! I didn't think to use street view. Good call, sorry for the false alarm. I should know better than to question your routes. 1 Link to comment
