KDeline Posted March 28 Share Posted March 28 Here is a picture of a Ram mount that I cannot find anywhere, even with the help of the people at Ram. Does anybody know where I can get this mount that replaces the cover for the steering bearing? I saw this on a video of how to remove the side panels but it’s from another country and a different language. Link to comment
Ron-M Posted March 29 Share Posted March 29 I have seen that mount as well, but doing a quick search, I could not find it. I have not given up though.. For some reason I think I saw someone discussing it on the bmwlt website. However, I found that Quadlock offers two versions of a fork stem mount. Don't know if this will work for you, but it is an option. Link to comment
Ron-M Posted March 29 Share Posted March 29 Here is another from Techmounts. https://techmounts.com/shop/ols/products/universal-motorcycle-fork-stem-mount-mount-only Link to comment
Ron-M Posted March 29 Share Posted March 29 And I finally found this from Ram Mounts. https://www.thevisorshop.com/en/us/RAM-Mounts-Stem-Mount-HD/m-22935.aspx?PartnerID=16&utm_source=google&utm_medium=cpc&utm_campaign=shoppingUnitedStates&gad_source=1&gclid=Cj0KCQjwzZmwBhD8ARIsAH4v1gUm9XGgKW4FyXxKnIVDErlfOC5XQORaLWHcSQYN4hvI8mjSSvZVAGIaAgTrEALw_wcB Link to comment
KDeline Posted March 29 Author Share Posted March 29 Thank you for looking, unfortunately I cannot see how it would work on the 1250. The fitment chart does not include the RT. Link to comment
konacyclist Posted March 29 Share Posted March 29 It looks like a Telferizer mount. A guy in the UK. Bob Telfer, makes them. info@telferizer.com. Link to comment
JCtx Posted March 29 Share Posted March 29 6 hours ago, KDeline said: Thank you for looking, unfortunately I cannot see how it would work on the 1250. The fitment chart does not include the RT. Indeed. They list 13, 15, and 19mm round holes, and at least my 1250R has a 12mm HEX hole instead. Not sure what the RT has, but probably the same nut, no? Does that 'Telfeizer' guy make that? If it's someething I can easily install and remove without tools, I'd consider such a mount. Looked for the Ram 'claw', but it's not made for my thick handlebars. I'd only use it if I need to use GPS in the future. Link to comment
KDeline Posted March 29 Author Share Posted March 29 2 hours ago, JCtx said: Indeed. They list 13, 15, and 19mm round holes, and at least my 1250R has a 12mm HEX hole instead. Not sure what the RT has, but probably the same nut, no? Does that 'Telfeizer' guy make that? If it's someething I can easily install and remove without tools, I'd consider such a mount. Looked for the Ram 'claw', but it's not made for my thick handlebars. I'd only use it if I need to use GPS in the future. I will check again, thanks. Link to comment
JCtx Posted March 30 Share Posted March 30 Thank you. Seems like the hole has to be round. It'd be quite expensive to machine a 12mm hex shaft, so guess we're out of luck for that location. Oh well. Need to check if Ram now makes a claw in large size. Link to comment
dreeves Posted March 30 Share Posted March 30 16 hours ago, KDeline said: Thank you for looking, unfortunately I cannot see how it would work on the 1250. The fitment chart does not include the RT. On my 2023 1250 RT the stem does not exist, only the thin casting of the top handlebar clamp. I searched all over for the same thing, to no avail…….. Link to comment
konacyclist Posted March 30 Share Posted March 30 I have a 2022 R1250RT and I purchased a Telferizer mount which comes with a RAM ball and works with the round opening beneath the BMW emblem in the center of the cast handlebar. Installation involves gently prying the BMW emblem off, and attaching the mount to the round opening in the handlebar casting. It’s a very simple procedure. Link to comment
Cap Posted March 30 Share Posted March 30 3 hours ago, konacyclist said: I have a 2022 R1250RT and I purchased a Telferizer mount ... https://www.telferizer.com/bmw/ Link to comment
KDeline Posted March 30 Author Share Posted March 30 6 hours ago, konacyclist said: I have a 2022 R1250RT and I purchased a Telferizer mount which comes with a RAM ball and works with the round opening beneath the BMW emblem in the center of the cast handlebar. Installation involves gently prying the BMW emblem off, and attaching the mount to the round opening in the handlebar casting. It’s a very simple procedure. Do you have a photo of it? I will need to make contact with them to find out the exact sized purchase. Link to comment
KDeline Posted March 30 Author Share Posted March 30 31 minutes ago, konacyclist said: Thank you, I have a request in to them. That’s exactly what I was looking for. Link to comment
JCtx Posted March 30 Share Posted March 30 Glad the RTs are that way, but it's a no-go for my R1250R. But it'd be more of a permanent install, so I'd much prefer a 'claw' the right size, since I could put it on and off in a minute. Link to comment
