wayneo Posted March 19 Share Posted March 19 On a 2005 R1200 ST odometer display is in miles. Same was with Triumph, but that can be switched back end forth, from metric, standard US or imperial. I wonder if that is possible with the beemers also? And if so, where could i find instructions about how to do it? Link to comment
dirtrider Posted March 19 Share Posted March 19 40 minutes ago, wayneo said: On a 2005 R1200 ST odometer display is in miles. Same was with Triumph, but that can be switched back end forth, from metric, standard US or imperial. I wonder if that is possible with the beemers also? And if so, where could i find instructions about how to do it? Afternoon wayneo Your dealer can do it with their shop computer. I'm not sure if the GS-911 can change the ST, should be able to but I haven't ever changed the ST so can't confirm that. Might even be able to do it with the cheaper MotoScan unit, but you would probably have to contact MotoScan to verify that it can. There is no easy button, it needs to be done using a remote scanner/computer connection. Esay way is to just ride with a GPS, more accurate & easy to switch between KPH & MPH. 1 Link to comment
wayneo Posted March 26 Author Share Posted March 26 On 3/19/2024 at 9:05 AM, dirtrider said: Afternoon wayneo Your dealer can do it with their shop computer. I'm not sure if the GS-911 can change the ST, should be able to but I haven't ever changed the ST so can't confirm that. Might even be able to do it with the cheaper MotoScan unit, but you would probably have to contact MotoScan to verify that it can. There is no easy button, it needs to be done using a remote scanner/computer connection. Esay way is to just ride with a GPS, more accurate & easy to switch between KPH & MPH. Thanks Oracle . I will reach out to him and figure thigs out . Link to comment
