matanuska Posted June 14, 2006 Share Posted June 14, 2006 This may have been asked before, but I searched and can't seem to find anything so bear with me. I'm at the point in my clutch replacement of reinstalling the clutch housing on the main engine output shaft. Problem is there is a rather thick o-ring that goes inside and for the life of me I can't see any way of getting it to slide over the splines. I've tried pressing with some jacking screws but can't seem to even get it started. I've read in the manual not to pound on the engine output shaft without the main shaft nut installed on the clutch housing. So how do I get this thing together? Anyone else done this before? Thanks Derek Link to comment
JerryMather Posted June 14, 2006 Share Posted June 14, 2006 Call me at American Turbo Power sometime today at 818 785-2900 if you need help when you do this. Steps : Thrust washer Clutch Housing O Ring Thrust Ring Split Type Nut Tighten Nut to140 Nm, then loosen it and retighten it to 50Nm and 60 degrees Link to comment
matanuska Posted June 14, 2006 Author Share Posted June 14, 2006 Thanks Jerry! I stared at the thing some more last night and I think I figured it out. My confusion came from when I originally removed the clutch housing. I didn’t take out the o-ring and when I pulled the housing off, somehow the old o-ring ended up in the internal groove machined about half way down the inside of the clutch housing splines, so naturally I assumed this is where it must go. However, when I went to put it back together I found there is no way in hell to get that o-ring to fit over the shaft splines, particularly when its inside that groove. After studying the parts and the drawings some more I realized the o-ring must go directly in front of the thrust ring and split nut after the housing is already installed on the shaft. There’s simply no other way to assemble it! Your sequence of steps above confirms that too. I’m still a little confused about the 60-degree thing. Maybe it’s just the terminology. I assume they are trying to say the wrench should be held at around the 2 to 3 o’clock position looking at the clutch housing? In other words, you need to be on the right side pushing down with the wrench as opposed to on the left side lifting up (or you’ll lift the engine – guess how I figured that one out!). Thanks again Derek Link to comment
Boffin Posted June 14, 2006 Share Posted June 14, 2006 They mean tighten to 50NM then through a further 60 degrees of rotation. Andy Link to comment
matanuska Posted June 14, 2006 Author Share Posted June 14, 2006 They mean tighten to 50NM then through a further 60 degrees of rotation. Andy Thanks Andy, That makes more sense. Just talked to Jerry and that's what he did too. I think I'm over analyzing this part of the reassembly! Link to comment
Dennis Andress Posted June 14, 2006 Share Posted June 14, 2006 They mean tighten to 50NM then through a further 60 degrees of rotation. Andy Thanks Andy, That makes more sense. Just talked to Jerry and that's what he did too. I think I'm over analyzing this part of the reassembly! Stay away from the Bridgeport.... Link to comment
