BeniciaRT_GT Posted March 2 Share Posted March 2 A rare find indeed! A seriously low mileage, literally new condition ADV bike. I am selling this for a friend and put 450 of the 708!!! total miles riding it from upstate NY to Va to help break it in properly. This bike was bought new 7/30/2016. Sadly, but lucky for you, it was parked and stored due to the owner no longer being able to ride. It did take a nap in the garage and there is a small spot from this tip over. All services are current. It is ready to ride anywhere in the world. I have the signed, clean title in hand. 2017 Triumph Tiger Explorer XRx USA: ENGINE AND TRANSMISSION Liquid cooled, 12 valve, DOHC, 1215cc 3cylinder 139 Hp (102 kW) @ 9,300 rpm 90.7 FTlbs (123 Nm) @ 6,200 rpm System Ride by Wire, fuel injection Exhaust Stainless steel 3 into 1 header system, side mounted stainless steel silencer Shaft drive Wet Clutch, multiplate hydraulically operated, torque assist 6speed transmission Single sided swingarm, cast aluminum alloy with shaft drive Front Wheels Cast aluminum alloy 10 spoke 19 x 3.0in Rear Wheels Cast aluminum alloy 10 spoke 17 x 4.5in 120/70 R19 front 170/60 R17 rear Front Suspension WP 48 mm upside down forks, electronically adjustable damping, 190mm travel (168 mm low seat version) Rear Suspension WP monoshock, electronically adjustable semi active damping, 193mm wheel travel (158 mm low seat version). Automatic preload adjustment Brakes Front Twin 305 mm floating discs, radially mounted monobloc Brembo calipers, 4piston, switchable ABS Brakes Rear Single 282mm disc, Nissin 2piston sliding caliper, switchable ABS Instrument Display and Functions Instrument pack with analogue tachometer, fixed segment LCD display and multifunction dot matrix LCD display. Fixed segment LCD display: speedometer, fuel gauge, gear position indicator, service indicator, clock, ambient air temperature, coolant temperature, cruise control status and set speed. Multifunction DOT matrix LCD display: three Riding Modes (Road, Rain, Off Road), windscreen adjustment, TSAS setting, Trip computer (journey distance, journey time, average fuel consumption, average speed), motorcycle information (odometer, range to empty, instantaneous fuel consumption, TPMS ready), settings menu, heated grips status, heated seat status ready. Low seat version: 30.9 31.7 in (785 805 mm) Wheelbase 59.8 in (1520 mm) Dry Weight Low seat version 538 lbs (244 Kg) 5.3 Gallon Tank Asking only $12,500 for this jewel. More pics here: https://beniciart-gt.smugmug.com/Triumph-1200-XrX-for-sale 1 Link to comment
Janky59 Posted March 4 Share Posted March 4 Maybe I missed it in the listing, but where is the bike currently located for checking out ? Virginia I presume, can you share the town/city ? I have a buddy in the market but likely out of his price range, and he’s a perpetual tire kicker but I love spending other people’s money. Link to comment
BeniciaRT_GT Posted March 5 Author Share Posted March 5 Yes, sorry! near Staunton Va. Link to comment
taylor1 Posted March 5 Share Posted March 5 9Mary7 We are trying to block Tewks from looking at or considering any more bikes until a Porsche is sitting in his garage. 3 Link to comment
9Mary7 Posted March 5 Share Posted March 5 7 hours ago, taylor1 said: 9Mary7 We are trying to block Tewks from looking at or considering any more bikes until a Porsche is sitting in his garage. My bad....I was unaware of this "plan" for our friend Pat. 1 1 Link to comment
TEWKS Posted March 6 Share Posted March 6 1 hour ago, Skywagon said: @TEWKS I’ve always thought this, the cemetery is the greatest equalizer. Link to comment
