Ozzyal Posted February 29 Share Posted February 29 Seems a strange question but here we go . I currently have alloy or cast wheels on my 2013 GS LC . I have purchased a spare set of spoked wheels of a 2015 . The Max's parts list shows that the 5 wheel studs are of the the same specification , M10x1.25x40mm , however they are listed as different part numbers . Can anyone shed some light on this ? Link to comment
dirtrider Posted February 29 Share Posted February 29 6 hours ago, Ozzyal said: Seems a strange question but here we go . I currently have alloy or cast wheels on my 2013 GS LC . I have purchased a spare set of spoked wheels of a 2015 . The Max's parts list shows that the 5 wheel studs are of the the same specification , M10x1.25x40mm , however they are listed as different part numbers . Can anyone shed some light on this ? Morning You didn't look one up for the wethead & look the other up for the camhead? My parts book shows them the same for the wethead. But BMW has been known to occasionally get things wrong in the parts diagrams so nothing is cast in stone. Spoke_____ 36 31 7 673 903 WHEEL BOLT - M10X1,25X40 Alloy______ 36 31 7 673 903 WHEEL BOLT - M10X1,25X40 Link to comment
Ozzyal Posted February 29 Author Share Posted February 29 Thanks . It was on the one schematic , so the same model . Size shows the specs but a different number . All good I'll risk using the same bolts , I'm sure it's just one of those strange things the germans do . Link to comment
duckbubbles Posted March 1 Share Posted March 1 I have seen different part numbers on the same part because of color choice (black/silver). Perhaps there is a slight design change between the two or different manufacturers. Frank 1 1 Link to comment
Hosstage Posted March 1 Share Posted March 1 That was my thought too, different colors for different wheels. Link to comment
Ozzyal Posted March 1 Author Share Posted March 1 Great thanks guys . I use to sell spare parts for earth moving equipment decades ago , so I'm reasonably confident I was reading it correctly . It was rare the same part has different part numbers , but not totally out of the question . I'd seen a Utube clip with an oil cooled model GS , the guy was swapping his cast wheels for spoked rims and in that video he pointed out that the spoked wheel needed a longer bolt . Which why I re checked the parts breakdown . The different numbers had me concerned until I noted the specification were same . Link to comment
dirtrider Posted March 1 Share Posted March 1 1 hour ago, Ozzyal said: Great thanks guys . I use to sell spare parts for earth moving equipment decades ago , so I'm reasonably confident I was reading it correctly . It was rare the same part has different part numbers , but not totally out of the question . I'd seen a Utube clip with an oil cooled model GS , the guy was swapping his cast wheels for spoked rims and in that video he pointed out that the spoked wheel needed a longer bolt . Which why I re checked the parts breakdown . The different numbers had me concerned until I noted the specification were same . Evening Ozzyal The thing is the wethead parts book might be incorrect (on length) as the camhead used different bolt lengths. Just check the amount of threads sticking out the rear of the wheel when you drop a bolt in the hole. If the same amount is sticking out on both wheels then the length is more than likely the same & book length is probably correct. 1 Link to comment
