dmsantam Posted February 18 Share Posted February 18 Good day all, the knee pad on the fairing of my R1100RT 1995 model is lifting a little, probably due to age. Does anybody have a solution to this? Should I remove it and try to straighten it? or do something with it on the fairing still? cheers, Dan Link to comment
Redfoxx Posted February 19 Share Posted February 19 that gray looks like 3m exterior foam 2 sided foam tape. Link to comment
dirtrider Posted February 19 Share Posted February 19 13 hours ago, dmsantam said: Good day all, the knee pad on the fairing of my R1100RT 1995 model is lifting a little, probably due to age. Does anybody have a solution to this? Should I remove it and try to straighten it? or do something with it on the fairing still? cheers, Dan Morning Dan I usually just clean the knee pad and clean the fairing pocket then glue the knee pad in with 3-M trim adhesive. Putting the removed knee pad out in the hot sun for a while can sometimes allow you to sort of re-shape it to better fit the panel hole. Depending on where the knee pad doesn't fit correctly there can be enough lip on the back side to drill a small hole in the lip then stick a small cotter pin though the hole to pin that area to stay tight to the fairing panel. 1 Link to comment
