RK Ryder Posted February 15 Share Posted February 15 Rather than going off tangent with the most recent thread, i am posting a new question. Since I do have a new sight glass in my bag of extras and although my K100 most likely has had the same sight glass for the last 284,000 kilometres. Would it be advisable and proactive to replace the existing sight glass or should I leave well enough alone? Presently the current one has absolutely no seepage. Link to comment
Skywagon Posted February 15 Share Posted February 15 DR is better equipped to answer this than me....but if your current lense is pretty clear, not leaking, and plastic...I would leave it alone. My understanding is the new lenses are glass and a real bugger to install often resulting in breaking them. Link to comment
dirtrider Posted February 15 Share Posted February 15 1 hour ago, RK Ryder said: Rather than going off tangent with the most recent thread, i am posting a new question. Since I do have a new sight glass in my bag of extras and although my K100 most likely has had the same sight glass for the last 284,000 kilometres. Would it be advisable and proactive to replace the existing sight glass or should I leave well enough alone? Presently the current one has absolutely no seepage. Afternoon RK Ryder If your present sight glass is not seeping & the rubber looks pristine then probably no hurry to replace. If the rubber is starting to look hardened, brittle, or minor cracking, then definitely replace it. If that sight glass you have in hand is the old plastic lens sight glass then that that thing is golden. THAT, is the one that you want to keep & carry as it can be installed with a screwdriver, proper sized socket, & a hammer while on the road. Link to comment
duckbubbles Posted February 16 Share Posted February 16 The original sightglass is still in my 330,000+ miles (528,000 km.) K100RS with no a problems. (Kiss of death) Frank 1 Link to comment
SDCRJohn Posted February 16 Share Posted February 16 26 minutes ago, duckbubbles said: The original sightglass is still in my 330,000+ miles (528,000 km.) K100RS with no a problems. (Kiss of death) Frank Frank, You made me laugh. i am going to have a close and intimate exam of my SG and the rubber trim. If it looks OK, I will take DR’s advice, and not mess with it. I also will be on the prowl for a plastic version to carry with me. John Link to comment
dirtrider Posted February 16 Share Posted February 16 9 minutes ago, SDCRJohn said: Frank, You made me laugh. i am going to have a close and intimate exam of my SG and the rubber trim. If it looks OK, I will take DR’s advice, and not mess with it. I also will be on the prowl for a plastic version to carry with me. John Morning John When looking for a plastic lens sight glass those usually have a pronounced red dot in the center. Both Euromotelectric & Beemer Boneyard have aftermarket sight glasses, I don't think they are plastic lens type but might be worth a call. Link to comment
RK Ryder Posted February 16 Author Share Posted February 16 From the above posts, I’ll leave the original sight glass in my ‘’87 K100RT.👍 However, dirtrider, being one who likes to be prepared for emergencies what is and where does one pickup a “expanding rubber freeze plug that fit the sight glass opening” that you mentioned in the previous SG thread. Cheers! Paul Link to comment
dirtrider Posted February 16 Share Posted February 16 9 minutes ago, RK Ryder said: From the above posts, I’ll leave the original sight glass in my ‘’87 K100RT.👍 However, dirtrider, being one who likes to be prepared for emergencies what is and where does one pickup a “expanding rubber freeze plug that fit the sight glass opening” that you mentioned in the previous SG thread. Cheers! Paul Afternoon Paul You want a short or shallow 1.5" rubber expanding freeze plug. If you get one that is tall it won't stay seated in the sight glass recess. Most auto parts stores have them, the problem is in finding a short one. Link to comment
SDCRJohn Posted February 16 Share Posted February 16 5 hours ago, dirtrider said: Afternoon Paul You want a short or shallow 1.5" rubber expanding freeze plug. If you get one that is tall it won't stay seated in the sight glass recess. Most auto parts stores have them, the problem is in finding a short one. Thanks for that DR. Link to comment
RK Ryder Posted February 16 Author Share Posted February 16 Thank you dirtrider! Paul Link to comment
Redfoxx Posted February 17 Share Posted February 17 10 hours ago, dirtrider said: Afternoon Paul You want a short or shallow 1.5" rubber expanding freeze plug. If you get one that is tall it won't stay seated in the sight glass recess. Most auto parts stores have them, the problem is in finding a short one. Don't forget to check nut size, it most likely is not metric, you may have to add a cresent wrench or correct wrench size. Link to comment
