SDCRJohn Posted February 10 Share Posted February 10 Since my 2000 R1100 RS is almost 25 years old, I am considering changing the oil sight glass, proactively. Has anyone here done this already, and can suggest how to complete the task successfully? thanks. John Link to comment
EEK Posted February 10 Share Posted February 10 Take a spring loaded punch and center punch window till it cracks. Get a screwdriver in the crack you just made and pry it out. Take a socket that is just a tad smaller diameter than new sight window, use it with extension and drive that sucker in! Easy peasy. Link to comment
dirtrider Posted February 10 Share Posted February 10 3 hours ago, SDCRJohn said: Since my 2000 R1100 RS is almost 25 years old, I am considering changing the oil sight glass, proactively. Has anyone here done this already, and can suggest how to complete the task successfully? thanks. John Afternoon John Years ago it was easy, not so much any longer as the new replacement sight glasses are now (& have been for quite a while now) actual glass lens. The older plastic lens sight glass is about impossible to find so unless you find a new old stock somewhere you will end up with the new difficult to install glass lens sight glass. Getting the old one out (assuming it is original & hasn't been replaced with a later glass lens one) is easy. I usually just heat a screw then turn it into the old sight glass then pry on the screw (I actually use a dent puller) to remove the old sight glass. Some just drive a screwdriver in then pry the old out but this method needs to be done with care as it can score the sight glass bore in the engine case & cause other issues. Installing the new "glass lens" one can be a challenge (especially if you haven't installed one before) as the glass lens extends out to under the rubber outer ring so using a socket or piece of pipe to drive it in can & sometimes will break the glass lens. It doesn't take many new glass lens breakages to add up to having the dealer install the new sight glass as they have the special tools to do it correctly. In any case, if you do it yourself, use a driver that just fits in the engine block hole without much clearance with a flat contact area that only contacts the very outer edge of the new sight glass (if the driver has too thick of a wall (like most sockets) it can contact the glass lens then crack it driving the new sight glass in. I usually use brake clean as a lubricant to drive the new one in BUT this method is for someone that has done a few before as you need to work very quickly as brake clean evaporates quickly. For people that work slower or haven't done the new "glass lens" install before then use Windex glass cleaner as a lube, it takes longer to evaporate so you have more working time but it takes longer to dry out between the sight glass rubber & the crankcase. 1 Link to comment
BABABeemer Posted February 11 Share Posted February 11 On 2/10/2024 at 11:26 AM, dirtrider said: I usually use brake clean as a lubricant to drive the new one in BUT this method is for someone that has done a few before as you need to work very quickly as brake clean evaporates quickly. For people that work slower or haven't done the new "glass lens" install before then use Windex glass cleaner as a lube, it takes longer to evaporate so you have more working time but it takes longer to dry out between the sight glass rubber & the crankcase. Afternoon DR, Would O2 sensor safe RTV silicone sealer act as a suitable lubricant to get the sight glass in? It has a long working time and additionally could act as a leak preventative once it set up properly. Link to comment
dirtrider Posted February 11 Share Posted February 11 8 minutes ago, BABABeemer said: Afternoon DR, Would O2 sensor safe RTV silicone sealer act as a suitable lubricant to get the sight glass in? It has a long working time and additionally could act as a leak preventative once it set up properly. Afternoon BABABeemer Sure it would, but it could also help it slide out later while riding. You want the rubber to be dry AFTER installation. So you need a lube that dries up & doesn't leave any slippery residue. BMW had a service bulletin to not use motor oil as a lubricant. Some BMW tecs did use tire mounting lube but BMW later retracted that suggestion (they didn't say why but they probably had some issues). If you could get it in dry that would be ideal but with that glass lens I seriously doubt you could get it in without breaking the glass. They are difficult enough to get in even with lube. 1 Link to comment
MichiganBob Posted February 12 Share Posted February 12 After reading this feedback SDCRJohn, are you inclined to go ahead. The Beemers I had with oil sight glass never failed me. 1 Link to comment
King Herald Posted February 12 Share Posted February 12 Is this a job that definitely needs to be done after a certain age or milage? I was told the HES will definitely fail around 50,000 miles. I chose to ignore the advice and mine did indeed dump me at the side of the road, at 62,000 miles. Only ten miles from home, but a week after returning from a 4000 mile tour of Europe…. Link to comment
dirtrider Posted February 12 Share Posted February 12 10 hours ago, MichiganBob said: After reading this feedback SDCRJohn, are you inclined to go ahead. The Beemers I had with oil sight glass never failed me. Morning MichiganBob Those older BMW 1100/1150 boxers had some sight glass issues. The plastic lens sight glass would become so yellow & clouded that riders couldn't tell if there was any oil behind it or not. There were also some cases where the sight glass rubber would degrade then the entire sight glass would pop out while riding, then dumping a crankcase full of oil on the riders L/H boot. I have also seen just the plastic lens pop out leaving the outer ring & rear baffle plate, again dumping oil out. A few also popped out in cold weather shortly after the rider rode off. I'm not really sure why but possibly due to the cold oil with the crankcase vent being restricted with thick cold engine oil allowing crankcase pressurization. I used to carry an expanding rubber freeze plug that fit the sight glass opening. I never needed it on my own motorcycle but used it a couple of times on other BMW 1100/1150 motorcycles that were on a ride that I was on. Link to comment
Lowndes Posted February 12 Share Posted February 12 14 hours ago, BABABeemer said: Afternoon DR, Would O2 sensor safe RTV silicone sealer act as a suitable lubricant to get the sight glass in? It has a long working time and additionally could act as a leak preventative once it set up properly. As a temporary lubricant for installing anything rubber, like hoses, seals, etc, P-80 by IPC is really good. Working time is 20 minutes to several hours depending on the product, after that it is gone like it was never there. The "P-80 Grip-It" might be the best choice for a sight glass: "P-80 Grip-It has low viscosity. It is formulated to leave a fine tacky residue on the surface to provide cling to the assembled parts. The estimated minimum dry time is approximately 20 minutes." The best part is that you can get a free sample from IPC: https://www.ipcol.com/request-assembly-lubricant-sample/ Also, the little sample tube they send will do about 20 sight glasses even if you are sloppy with it. It works great on oil seals, too. I'm not affiliated with IPC in any way other than as a very satisfied customer and personal witness to how good this stuff is. Lowndes Link to comment
SDCRJohn Posted February 12 Author Share Posted February 12 11 hours ago, MichiganBob said: After reading this feedback SDCRJohn, are you inclined to go ahead. The Beemers I had with oil sight glass never failed me. This morning, I am on the fence. I think if I could locate a plastic version, I would feel more confident to tackle this. John Link to comment
dirtrider Posted February 12 Share Posted February 12 24 minutes ago, Lowndes said: As a temporary lubricant for installing anything rubber, like hoses, seals, etc, P-80 by IPC is really good. Working time is 20 minutes to several hours depending on the product, after that it is gone like it was never there. The "P-80 Grip-It" might be the best choice for a sight glass: "P-80 Grip-It has low viscosity. It is formulated to leave a fine tacky residue on the surface to provide cling to the assembled parts. The estimated minimum dry time is approximately 20 minutes." The best part is that you can get a free sample from IPC: https://www.ipcol.com/request-assembly-lubricant-sample/ Also, the little sample tube they send will do about 20 sight glasses even if you are sloppy with it. It works great on oil seals, too. I'm not affiliated with IPC in any way other than as a very satisfied customer and personal witness to how good this stuff is. Lowndes Morning Lowndes What is the working temperature of this product? Will it give up it's grip at high crankcase temperatures? Will hot motor oil effect it? You really want rubber to clean alloy when all is done & evaporated. Link to comment
Lowndes Posted February 12 Share Posted February 12 3 minutes ago, dirtrider said: Morning Lowndes What is the working temperature of this product? Will it give up it's grip at high crankcase temperatures? Will hot motor oil effect it? You really want rubber to clean alloy when all is done & evaporated. Good question. What temps would the sightglass see in normal or "extra normal" use, other than a meltdown?? Link to comment
dirtrider Posted February 12 Share Posted February 12 1 minute ago, Lowndes said: Good question. What temps would the sightglass see in normal or "extra normal" use, other than a meltdown?? Morning Lowndes It can see oil temperature & that can go as high as 225°f (or even higher) in some cases. The new official BMW sight glass install procedure is pretty direct in saying to use "brake clean" as other lubricants can cause the seal to pop out. Brake clean is the best but you need to work pretty darn fast using brake clean. Link to comment
Redfoxx Posted February 12 Share Posted February 12 1 hour ago, dirtrider said: Morning Lowndes It can see oil temperature & that can go as high as 225°f (or even higher) in some cases. The new official BMW sight glass install procedure is pretty direct in saying to use "brake clean" as other lubricants can cause the seal to pop out. Brake clean is the best but you need to work pretty darn fast using brake clean. DR I just requested sample an asked them about handling heat and residue. It didnt like my email so I went through contact them. Not sure on time line on their response. RF Link to comment
Lowndes Posted February 12 Share Posted February 12 Redfoxx, I submitted the question at 8:48 AM to IPC and got a reply from Jennifer Sun, PhD, R&D Manager at 9:41 AM, asking for clarification. I replied at 10:02 AM so we'll see what they say. Lowndes Link to comment
Lowndes Posted February 12 Share Posted February 12 I checked the temperature stability of Polyethylenimine. Google says Polyethylenimine degrades from 140-160°C (284° - 320°F). Link to comment
Redfoxx Posted February 12 Share Posted February 12 11 minutes ago, Lowndes said: I checked the temperature stability of Polyethylenimine. Google says Polyethylenimine degrades from 140-160°C (284° - 320°F). When it degrades, I wonder if it becomes slimy, if not I would not think it would effect it, the oil window, should still be held in by the rubber seal material and friction? Link to comment
Lowndes Posted February 12 Share Posted February 12 If your engine gets to 284°F you have other problems bigger than a sightglass seal. 1 Link to comment
dirtrider Posted February 12 Share Posted February 12 8 minutes ago, Redfoxx said: When it degrades, I wonder if it becomes slimy, if not I would not think it would effect it, the oil window, should still be held in by the rubber seal material and friction? Afternoon RF Personally I would just stick with what I know for sure works and what BMW recommends in a service bulletin. That is brake clean. 1 Link to comment
Lowndes Posted February 13 Share Posted February 13 Personally, I would not replace the sightglass. "If it ain't broke, don't fix it". Also, personally, I wouldn't want any brake cleaner getting into my engine oil. 1 Link to comment
dirtrider Posted February 13 Share Posted February 13 1 hour ago, Lowndes said: Personally, I would not replace the sightglass. "If it ain't broke, don't fix it". Also, personally, I wouldn't want any brake cleaner getting into my engine oil. Morning Lowndes Personally, I would not replace the sightglass. "If it ain't broke, don't fix it".-- Yes, that would be desired but on some old 1100/1150 boxers with severely yellowed or browned sight glass lens, if you want to be able to read the oil level then you need to replace it as some of them are so bad you can't see through them. Also, if the rubber around the sight glass is degrading (some get that way) or crumbling then you either replace it before it pops out or do it after it pops out while riding. Just a life choice thing. Also, personally, I wouldn't want any brake cleaner getting into my engine oil.-- I hear you, I don't want ANYTHING getting into my engine oil. Most do change the engine oil or drop it before installing the sight glass but even if the oil it left in the engine you don't spray a bunch into the engine. It evaporates very quickly. More than likely a person will need to use something like brake clean to thoroughly clean the sight glass pocket in the engine case anyhow so why not just use it as lubricant. It IS the BMW recommended product to use to install a sight glass so if BMW is OK with it so am I. And without a lot of testing we really don't know if brake clean is any better or worse than that P-80 Grip product getting into the engine oil. Link to comment
6speedTi Posted February 13 Share Posted February 13 I've learned from experience that using a non chlorinated brake clean is less harmful to plastic and rubber. It still has volatile chemicals but a better choice. In reference to this topic non chlorinated brake clean has a longer evaporation drying time than chlorinated brake clean. How much longer drying time depends on what you are using it for. In this case it might make a difference depending how fast you work. Link to comment
SDCRJohn Posted February 13 Author Share Posted February 13 Here is a pic of my 2000 RS sight glass. I don’t see any misting around it. Link to comment
Lowndes Posted February 13 Share Posted February 13 Nothing wrong with that sight glass, SDCRJohn, it's your oil that needs changing!! 1 Link to comment
SDCRJohn Posted February 14 Author Share Posted February 14 23 minutes ago, Lowndes said: Nothing wrong with that sight glass, SDCRJohn, it's your oil that needs changing!! Really? I just changed it 500 miles ago… Link to comment
JamesW Posted February 14 Share Posted February 14 What I did some time ago to my '93 R1100RSL which was drill 4 small holes 90 degrees apart carefully on the raised metal edge around the sight glass then install lock wire through the holes as shown in the photo. 1 Link to comment
Lowndes Posted February 14 Share Posted February 14 It just looks kinda dark. Could be the brand of oil that is normally darker. But your bike is way too clean. Link to comment
Jim Moore Posted February 14 Share Posted February 14 9 hours ago, JamesW said: What I did some time ago to my '93 R1100RSL which was drill 4 small holes 90 degrees apart carefully on the raised metal edge around the sight glass then install lock wire through the holes as shown in the photo. I did the same thing, but I just ran the wire from one bolt to another bolt, across the face of the sight glass. Link to comment
SDCRJohn Posted February 14 Author Share Posted February 14 3 hours ago, Jim Moore said: I did the same thing, but I just ran the wire from one bolt to another bolt, across the face of the sight glass. I like both of these ideas, especially, if your sight glass looks “Ok”. But, if the sight glass lets go, ie, exits the sight glass bore, will the wire(s) prevent the glass from completely releasing from the bike? Link to comment
Redfoxx Posted February 14 Share Posted February 14 14 hours ago, SDCRJohn said: Really? I just changed it 500 miles ago… What are you using for oil, because that looks really dark. I got 1000 miles on my oil looks like the picture with wires, I am running AMSOIL Metric full synthetic 15w-50. Link to comment
SDCRJohn Posted February 14 Author Share Posted February 14 21 minutes ago, Redfoxx said: What are you using for oil, because that looks really dark. I got 1000 miles on my oil looks like the picture with wires, I am running AMSOIL Metric full synthetic 15w-50. Golden Spectro 20/50 synthetic blend. it could also be from the lighting in my garage, as the left jug was shadowing the glass. Link to comment
JamesW Posted February 14 Share Posted February 14 1 hour ago, SDCRJohn said: I like both of these ideas, especially, if your sight glass looks “Ok”. But, if the sight glass lets go, ie, exits the sight glass bore, will the wire(s) prevent the glass from completely releasing from the bike? I think it would be somewhat difficult for the sight glass to get past the lock wire and the wire does keep pressure on the glass assembly. Also, I think if anything it will prevent a rapid all over the place oil dump so much better than nothing and easy to install. Link to comment
Redfoxx Posted February 14 Share Posted February 14 3 hours ago, SDCRJohn said: Golden Spectro 20/50 synthetic blend. it could also be from the lighting in my garage, as the left jug was shadowing the glass. SDCR I used to run that in my Wing, never remember it being that dark. On my BMW I can normally pretty much see through the oil for a long time. I guess I would keep an eye on it. Your site glass looks clearer than mine, my BMW turns 22 in June. RF Link to comment
dirtrider Posted February 14 Share Posted February 14 7 hours ago, SDCRJohn said: Golden Spectro 20/50 synthetic blend. it could also be from the lighting in my garage, as the left jug was shadowing the glass. Evening SDCRJohn That color is probably due to the discoloration of your old plastic lens sight glass. When they discolor everything inside looks darker. Link to comment
steve68 Posted March 24 Share Posted March 24 Does the engine oil have to be completely drained to do this procedure? I would think not. I have to do this on my 02 R1150R cause the sight glass is totally opaque. Link to comment
dirtrider Posted March 24 Share Posted March 24 2 hours ago, steve68 said: Does the engine oil have to be completely drained to do this procedure? I would think not. I have to do this on my 02 R1150R cause the sight glass is totally opaque. Afternoon steve68 No, you can do it with the oil in the engine if you put a folded blanked or old coat on the ground then lay the motorcycle over on the R/H side valve cover. Link to comment
steve68 Posted March 25 Share Posted March 25 Great, thanks. What is the preferred method? Pry it out with a screwdriver? I've seen some less than encouraging youtube videos. Any tricks or tips? Link to comment
dirtrider Posted March 25 Share Posted March 25 1 hour ago, steve68 said: Great, thanks. What is the preferred method? Pry it out with a screwdriver? I've seen some less than encouraging youtube videos. Any tricks or tips? Morning Steve THAT DEPENDS, on if the sight glass in the engine NOW is a plastic or glass lens and if the one you are installing is a plastic or glass lens. If a brand new (just bought sight glass then probably a glass lens as that is all that is available now) If the old one is plastic lens then heat a nail or old screwdriver then push that through the plastic lens, then put a sheet metal screw into the old sight glass inner plate then grab that with vise grips & pry it out, or just carefully pry the old one out once you get something through the lens. (sometimes on old really stuck ones you have to be creative). On installing a glass lens sight glass, you REALLY need to know what you are doing as the glass lens cracks easily (that gets expensive in a hurry) You need a perfect fitting driver that just catches to outer edges of the sight glass but doesn't extend inwards over the actual glass part. Most large sockets are just thick enough to possibly break the glass lens. (sometimes they work & sometimes they don't) __It gets expensive if a socket doesn't work. The hole in the engine block needs to be squeaky clean & the new sight glass needs to be lubricated with an evaporating (non-residue leaving) lubricant. Caution: do not use motor oil or grease! BMW recommends Brake Clean as a lubricant but that is only if you are a fast & precise worker, if you work slow it will evaporate before you get the new sight glass all the way in. For slower workers, or workers with not the best fruiting driver or drive angle I recommend using Windex glass cleaner as a lubricant as it takes longer to evaporate. Link to comment
steve68 Posted March 25 Share Posted March 25 Great. Makes sense. I am pretty sure the current is plastic so I'll try those ideas - Windex sounds like my ticket. I was thinking of maybe trying a small length of appropriate diameter PVC pipe, or a square piece of wood block flat over the new sight glass. Sound reasonable? Link to comment
dirtrider Posted March 25 Share Posted March 25 10 minutes ago, steve68 said: Great. Makes sense. I am pretty sure the current is plastic so I'll try those ideas - Windex sounds like my ticket. I was thinking of maybe trying a small length of appropriate diameter PVC pipe, or a square piece of wood block flat over the new sight glass. Sound reasonable? Morning Steve I'm not sure I would try to cover the entire sight glass as that will put pressure on the outer edges of the glass lens. If you can get the PVC pipe OD to JUST slide in the engine block hole & the ID to not put pressure on the outer edges of the glass lens then it should work. If possible try to drive on the center of the PVC so you drive the sight glass in evenly. I can't stress enough on how easy it is to break that glass lens with an incorrect driver. Link to comment
