Dave Cameron Posted January 14 Share Posted January 14 2013 R1200RT want to change clutch fluid. how do you reach bleed connection ? I believe I, see it I, think front of rear suspension spring. Can’t figure out how to access. Thanks Link to comment
dirtrider Posted January 14 Share Posted January 14 49 minutes ago, Dave Cameron said: 2013 R1200RT want to change clutch fluid. how do you reach bleed connection ? I believe I, see it I, think front of rear suspension spring. Can’t figure out how to access. Thanks Morning Dave The easiest way is to remove the L/H side footrest plate. That allows decent access. This is also the way the BMW manual says to do it. If you have skinny arms & smaller hands & can work blind then you can sometimes weasel your arm in there without removing the footrest plate.. Link to comment
Dave Cameron Posted January 14 Author Share Posted January 14 Don’t have small hands . Removing foot rest no biggie. Thank you Dave Link to comment
