pwillikers Posted January 8 Share Posted January 8 My instrument cluster's temperature reading is showing, ---F°, no reading. The connector to the black pointy temp sensor on the lower right front fairing is delivering ~4.5V to the sensor. The resistance across the disconnected sensor's pins is ∞. Thus, I conclude that the sensor itself is bad. I ordered a replacement from ebay. Is this sensor used for any critical engine (or other) function? Is it safe to motor about for the ensuing weeks until the replacement is installed? Link to comment
RadioFlyer Posted January 9 Share Posted January 9 It is not involved in engine management. The ECU uses engine temp and intake air temp. Link to comment
dirtrider Posted January 9 Share Posted January 9 15 hours ago, pwillikers said: My instrument cluster's temperature reading is showing, ---F°, no reading. The connector to the black pointy temp sensor on the lower right front fairing is delivering ~4.5V to the sensor. The resistance across the disconnected sensor's pins is ∞. Thus, I conclude that the sensor itself is bad. I ordered a replacement from ebay. Is this sensor used for any critical engine (or other) function? Is it safe to motor about for the ensuing weeks until the replacement is installed? Morning pwillikers In addition to what RadioFlyer posted above it also effects your dash ice warning indicator. That displays a snowflake on the dash indicating that the ambient temp is lower than 37 °F (3 °C). Link to comment
pwillikers Posted January 13 Author Share Posted January 13 The ebay ambient air temperature sensor arrived, has been installed and works perfectly. Total cost: $5.55. :-) 1 Link to comment
